Version 3.8.7b - 01.29.2025
- Fixed a bug with the baluster options.
- Enabled a zero stringer option for floating stairs.
Just a few more loose ends before I jump back to the Floor plugin.
I would like to enable landing treads for winders, but things get a little interesting when the min. winder length is set to zero.  Does this look okay?
Version 3.8.8 - 02.06.2025
- Added landing treads, tread covers, carpet and stair runners for a winders.
- Added an SIP wall framing option for all wall types.
- Added five additional SIP parameters into the wall Draw and Edit menus.
Tutorial 66 - SIP Walls (8:03 min.)
Version 3.8.8b - 02.06.2025
- Added the option for closed stringers.
mdkBIM Renewals - UPDATE (Feb. 8, 2025)
For those who can not be bothered to renew each license separately, I have come up with a solution finally. If you are mdkBIM license holder (ie. you have all five licenses - Wall, Truss, Floor, Foundation, and Project) you will now notice that when you click on the mdkBIM icon in the Account Manager on the Medeek website that the renewal price will appear instead of the regular "new" price. In other words you can purchase a new mdkBIM bundle (all five licenses) at the renewal price.
Note, that this is technically not a renewal of any of your licenses, it simply allows you to purchase new licenses at the discounted (renewal) price. For those who are wanting to sync up all their licenses to the same renewal date this is a convenient solution. However, note that if time is remaining on any existing licenses it is not applied to the new licenses.
Version 3.8.9 - 02.09.2025
- Added preview thumbnails for handrail fittings to the draw and edit menus of the stair tool.
- Fixed a bug with adjacent winders/landings for landing treads and covers.
- Fixed a minor bug with materials for handrail fittings.
Version 3.9.0 - 02.11.2025
- Enabled zero size intermediate posts (balusters) for glass railing.
- Fixed a bug with floor level winders/landings for landing treads and covers.
Version 3.9.0c - 02.12.2025
- Fixed a bug when the top tread is flush.
Version 3.9.0d - 02.14.2025
- Fixed a floating point rounding bug for metric templates.
- Fixed a bug for balusters when a run of stairs is a single step.
Still putting out a few little fires.  Whenever you make big changes it always seems like you miss something or you add a new feature that adds a whole new level of complexity, and then the plugin gets itself into states that you did not foresee.  That is what makes this job fun, you get surprised once in a while.
Please feel free to send me any additional bug reports or feature requests.  I think we've just about wrapped up the stair module for a while.
Version 3.9.1 - 02.23.2025
- Added the following (48 - low poly) Simpson post caps to the post module: CC1210, CC718_718, CC718_8, CC718_6, CC718_4, CC514_8, CC514_6, CC514_4, CC462_550, CC462_462, CC462_362, CC314_6, CC314_4, CC128, CC126, CC106, CC98, CC96, CC94, CC88, CC86, CC84, CC78, CC77, CC76, CC74, CC68, CC66, CC64, CC48, CC46, CC44, CC6_718, CCO4, CCO6, CCO7, CCO8, CCO9, CCO10, CCO12, CCO46, CCO314, CCO462, CCO514, CCO718, ECC64, ECC66, ECC68.
I still need to add in the rest of the ECC series, so there is always more to do.
Version 3.9.2 - 03.15.2025
- Enabled an edge material/texture for built-in gypsum wall materials.
Version 3.9.3 - 03.29.2025
- Added the following Simpson Strong-Tie holdowns to the wall, column and shearwall modules: DTT1Z, LTTP2, LTTI31.
- Added the following Simpson Strong-Tie holdowns to the wall, column and shearwall modules: HD3B, HD5B, HD7B, HD9B, HD12, HD19.
- Updated the wall and column modules so that they include all previous holdowns that were added to the shearwall module.
I think I now have added every common holdown used for walls and columns that is found in the Simpson Catalog [Wood Construction Connectors 2024-2025] (pg. 51-65).
