0 Members and 37 Guests are viewing this topic.
Version 3.0.9 - 01.05.2023
- Enabled beam pockets (in-wall columns) for CMU, CMU Core and ICF walls.
- Fixed a bug within the plan view auto-dimensioning module having to do with in-wall columns.
- Fixed a minor typo in the Draw menu for in-wall columns.
Version 3.1.0 - 01.11.2023
- Enabled layer control integration with the Medeek Project extension.
- Moved the Medeek Estimating module to the Medeek Project extension.
- Moved the Medeek Documents module to the Medeek Project extension.
Version 3.1.1 - 01.19.2023
- Fixed a bug with ICF Walls.
- Fixed a type in the HTML of the General tab of the Global Settings.
Tutorial 32 - Auto-Dimensioning (9:31 min.)
Tutorial 33 - ICF Walls (5:51 min.)
Version 3.1.2 - 02.05.2023
- Fixed a bug with metric templates that propagated from Version 3.0.8.
- Fixed a specific bug with auto-loading wall presets.
! ATTENTION !
Critical bug fix, especially for metric templates.  I highly recommend upgrading to Version 3.1.2 if you have installed Version 3.0.8 or later.
The auto-load bug has to do with enabling the auto-load preset option in the Global Settings and then subsequently deleting the preset that was selected as the default auto-load preset.
Version 3.1.2b - 02.07.2023
- Fixed a minor bug with the Wall Selector Matrix (Gable, Shed and Hip walls).
This bug was due to some consolidation and general house cleaning I did with the code a few cycles back.  Even when a gable wall was selected it would automatically revert to a rectangular wall.  I just noticed this yesterday but the bug probably has been around for at least a month.
Version 3.1.3 - 02.16.2023
- Fixed a bug with door presets within the Edit Door menu.
Version 3.1.4 - 03.12.2023
- Added the following door types: flat one panel (single and double).
Version 3.1.5 - 03.17.2023
- Added a fluting number parameter for classical columns.
Really wasn't wanting to dig into this right now but after a quick inspection of my code I realized it would only take me a few minutes to add in this additional parameter so that one could fine tune the look of the fluting of classical columns.
I thought I would circle back to inclined walls since I had some questions on shed dormers over the weekend.
I've updated the wall menus to include these new parameters now I just need to create the boolean logic to modify the wall geometry accordingly:
This feature should give the user the flexibility to modify rectangular, hip, shed or gable walls as needed when an inclined bottom plate is required.
Version 3.1.6 - 03.26.2023
- Added inclined walls for all wall types: rectangular, shed, gable and hip.
This new feature can also be used on CMU, ICF and CMU CORE walls.
Version 3.1.7 - 06.12.2023
- Reorganized the window draw and edit menus to include an annotations section.
This is a fairly minor update however I felt it necessary so that consistency is maintained with the Door menus.
Version 3.1.8 - 06.27.2023
- Enabled FIS notation for framing (elevation view) dimensions for rectangular walls.
- Enabled FIS notation for plan view dimensions for all walls.
FIS stands for Feet-Inches-Sixteenths, a common notation method used in the truss industry.  This update per customer request.
Version 3.1.9 - 07.12.2023
- Added an "Edit Dimension" tool to the Medeek Wall Tools toolbar (editing of plan dimension only).
- Enabled editing of plan dimensions for all wall types (door, window, garage, wall length).
- Fixed a bug with plan dimensions (in 2D Mode).
Note that this new tool can only be used to edit "plan" dimensions.  Framing dimensions are currently not editable.  This update was per customer request.
