0 Members and 153 Guests are viewing this topic.
Version 3.5.3 - 03.06.2024
- Added a "Panel" corner treatment for "End" and "Terminal" wall corners (rectangular walls only).
- Fixed a javascript bug for window and door presets.
- Fixed a bug with the door casing (custom casing options) and end cripple studs for pocket doors.
- Rearranged the door casing section of the door Draw and Edit menus.
- Fixed a bug with the advanced options for all wall types when using metric templates.
With this release I've fixed a number of substantial bugs that were discovered by users and also one by myself.  I highly recommend upgrading to this latest release of the plugin.
Version 3.5.4 - 03.08.2024
- Enabled an end grain material for top and bottom plates of rectangular walls.
- Fixed a javascript bug for garage door presets.
- Fixed a bug with door presets when using metric templates.
Version 3.5.4b - 03.09.2024
- Enabled a pressure treated end grain material for bottom plates of all walls.
- Enabled end grain materials for in-wall columns.
- Enabled end grain materials for beams.
- Enabled end grain materials for blocks.
- Enabled end grain materials for posts.
Version 3.5.5 - 03.11.2024
- Added a "Custom Glass" garage door type/option with fully customizable glass panels.
- Further refined the end grain material positioning for top plates (rectangular walls) and in-wall columns.
I will need to create a tutorial video explaining the proper syntax for the "Glass List".
Medeek Wall Plugin **Tutorial 47** - Custom Glass Garage Doors (w/ Webcam)
In the next update I will be adding a "taped" drywall/gypsum material option:
This is primarily for garages and other semi-finished spaces, so that a more realistic look is obtained.  The tiling of the gypsum is 4x8 sheets oriented horizontally.  The texture is mostly seamless, so I am fairly pleased with it.  If there is further interest I could also provide a 4x12 option as well, but for now I feel like the 4x8 option is probably the most standard and should suffice for most projects.
#1116
Version 3.5.6 - 03.21.2024
- Added built-in "Taped" and "Green Taped" gypsum materials for all wall types.
- Updated and added additional tool tips within the Global Settings.
Version 3.5.7 - 04.17.2024
Version 3.5.8 - 04.25.2024
- Fixed a bug with cripple studs over windows and doors.
- Fixed a bug with the copy wall tool.
Version 3.5.9 - 05.01.2024
- Added a rainscreen option for gable walls (vertical, horizontal, 45 and 135 degree).
- Added a rainscreen option for shed walls (vertical, horizontal, 45 and 135 degree).
- Added a rainscreen option for hip walls (vertical, horizontal, 45 and 135 degree).
- Updated the license verification system with a more secure and improved algorithm.
#1120
Version 3.6.0 - 05.04.2024
- Added the ability to create custom "Vertical Shiplap" wall cladding materials within the Material Library.
- Enabled "3D" Vertical Shiplap wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
- Added the ability to create custom Dutchlap" wall cladding materials within the Material Library.
- Enabled "3D" Dutchlap wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
The original 3D cladding tutorial showed the following four materials:
- Board and Batten
- Shiplap
- Log
- Lap
The three additional ones added since this video are:
- Metal
- Shiplap (Vertical)
- Dutchlap
There are now seven different types of 3D cladding materials one can configure within the Custom Material Library.
Version 3.6.1 - 05.13.2024
- Added Symbol 2 Layer specfically for 2D door swing symbols (Layer tab of the global settings).
Version 3.6.2 - 05.14.2024
  • Enabled wall sheathing 2 statistics for the Medeek Estimating Module.
  • Fixed a bug with wall presets and the wall sheathing 2 option.
I will be running a Memorial Day promotion beginning May 22th until Jun. 5th with 35% off of the regular mdkBIM bundle price (permanent license) using the coupon code MEMORIAL24.
This will reduce the bundle price from $280.00 USD to $182.00 USD. This promo code does not apply to any of the extensions purchased separately.  As part of this promotion a permanent license for the electrical plugin will be included upon request. The offer ends on Jun. 5th and no rain checks will issued thereafter.
design.medeek.com
