0 Members and 114 Guests are viewing this topic.
For large agricultural buildings a double inverted truss can be employed to provide a large vaulted span for machinery:
I am wondering if this truss type is still commonly used by anyone for this type of application and whether it would be of interest, enough for me to add it into the growing list of trusses within the plugin.
Also if anyone has any shop drawings they could send me that would be very helpful.
A quick study of a double inverted truss by taking two 24' howe trusses and joining them to form a double truss.  Note that the 4:12 pitch of the original trusses is maintained and the interior vault is exactly 8:12 pitch.
https://3dwarehouse.sketchup.com/model.html?id=d1f62979-cea5-42f0-97e4-16309098928a
My question with this configuration is how the top and bottom chords at the peak should butt up?  For example should the bottom chords at the peak have a double scarf cut or a single scarf cut?  Some shop drawings would help in determining what is common practice.
Version 1.5.7 - 05.15.2016
- Added Scissor truss type, configurations: (4/2, 6/4).
- Structural outlookers (vert. & horz.) enabled under advanced roof options for Scissor (4/2, 6/4) truss types.
https://3dwarehouse.sketchup.com/model.html?id=620e816e-d809-4732-a19f-e425b4cc17fc
I also updated the pause in the truss selector GUI from 700 ms to 400 ms.  Still more work to be done with raised heels and structural outlookers for some of these configurations but its getting close.
#198
Coffer Truss Algorithm:
This is assuming that the coffer span is centered on the truss.  A non-centered coffer algorithm could get significantly more interesting and difficult.
This map shows where the Truss Plugin is being utilized:
http://design.medeek.com/calculator/sketchup/data/medeektrusspluginusermap.pl
Note, this is only registered users and not all installations of the trial version.  Also note that addresses have been dumbed down to City, State, Country so that the privacy of registered users is upheld.
Version 1.5.8 - 05.22.2016
- Added metric input for Gambrel Attic truss type.
- Added a graphical user interface (GUI) for metric gambrel attic geometry input.
Gambrel Attic (metric) GUI
I also show the industry standard feet-inches-sixteenths.
Version 1.5.9 - 05.29.2016
- Increased top chord pitch limit from 12/12 to 18/12 for the following Scissor truss types, configurations: (2/2, 4/4).
- Heel web logic revised to accommodate steeper pitches for bottom and top chords of scissor trusses.
- Increased top chord pitch limit from 12/12 to 18/12 for valley truss sets.
16/12:12/12 Scissor Truss with an 18" raised heel:
Notice that the steep pitch of the bottom chord changes the way the heel web and bottom chord meet at the bearing point.  The additional logic listed in the changelog notes deals specifically with this issue.
https://3dwarehouse.sketchup.com/model.html?id=6c14d6c0-14c3-44cc-ba76-e4771fbfa936
I will probably add the symmetric cathedral truss type next:
https://3dwarehouse.sketchup.com/model.html?id=1fb7807d-2d62-447e-86db-52cd98432a29
The web configurations will use an "auto" triangulation algorithm similar to the tray truss type.
Version 1.6.0 - 06.08.2016
- Corrected a bug with raised heel fink trusses and structural outlookers.
Various configurations of a 16' King Post Truss:
https://3dwarehouse.sketchup.com/model.html?id=d38c0061-b812-499a-b02a-70c43148d958
With a raised heel note the use of either a wedge, slider or vertical web with strut.
Version 1.6.1 - 06.11.2016
- Added Coffer truss type, configurations: (AUTO).
- Metric input enabled for coffer truss type.
- Added gable end trusses for coffer truss type.
- Structural outlookers (vert. & horz.) enabled under advanced roof options for Coffer truss type.
- Building parameter menu (2nd) and advanced options menu for trusses now default to last picked options of the session for that sub-menu item.
Various configurations of a 40' coffer truss shown below:
The web triangulation algorithm automatically determines which configuration is appropriate based on the span between panel points.  This simplifies the geometry input menu but does take some control from the user.
https://3dwarehouse.sketchup.com/model.html?id=a9f2e281-557d-4d13-a9ad-64bdfdd078f4
Version 1.6.2 - 06.14.2016
- Added Symmetric Cathedral truss type, configurations: (AUTO).
- Metric input enabled for symmetric cathedral truss type.
- Added gable end trusses for symmetric cathedral truss type.
- Structural outlookers (vert. & horz.) enabled under advanced roof options for Symmetric Cathedral truss type.
Various sizes and configurations of a symmetric cathedral truss:
https://3dwarehouse.sketchup.com/model.html?id=2755897d-3855-447a-bc13-d4478cf99355
Modified an existing truss roof to make it a half hip truss set:
https://3dwarehouse.sketchup.com/model.html?id=6e2633ca-ebb2-4597-87e9-ba41b47a636f
This will be my first venture into more complex truss systems.  I figured I would cut my teeth on the half hip (Jerkin Head, Tudor Hip) truss set first before attacking the more complex full hip variants of which there are many.
After sketching this model up and examining the geometry I now have a number of questions:
1.  Are my roof planes correct?  Note that I have drawn the apex of the hip roofs at the edge of the last full truss and not at its centerline.  Not entirely sure what is common practice in this regard.
2.  I've shown some non-structural outlookers along the rake.  What would the outlookers along the half hip portion look like?
3.  If I use structural outlookers how would those be framed in over the hip section?
4.  Does the apex of the half hip typically coincide with the next truss or could it land somewhere between trusses?  ie. the half hip length is some multiple of the truss spacing.
5.  Is the hip section usually the same pitch as the rest of the roof?  There is really no reason why it has to be.
6.  As the length of the half hip increases the depth of the gable end truss decreases as does the first inboard truss.  What is the practical limit for the minimum depth of the first inboard truss?
7.  Does anyone have some shop drawings of this type of truss set that I can study?
As previously noted the web dialog from the plugin can actually be used external to SketchUp to explore gambrel attic geometry:
Imperial Units:
http://design.medeek.com/resources/gambrel/web_dialog_gambrel_attic.html
Metric Units:
http://design.medeek.com/resources/gambrel/web_dialog_gambrel_attic_metric.html
I might develop this into a web based app which would allow one to generate 2D AutoCAD geometry (.dwg) of the truss profile.
