0 Members and 66 Guests are viewing this topic.
It looks like I will need to add in one additional option, Weather Proof GFCI.  It seems that this combination is fairly popular:
My weatherproof cover is based on the Taymac MM420C, probably a little more detail than it needs but I wanted it to look somewhat recognizable.
I also have the Decora option and the standard duplex option.
Has anyone ever called out duplex receptacles with the integrated USB chargers?
https://www.leviton.com/en/products/t5632-w
I'm assuming the callout would just be a standard duplex symbol with the annotation "USB" added.
These type of outlets have a small parasitic load (50 mW), but I think many people are willing to accept that loss for the convenience. My worry would be that the device fails down the road and then I need to replace it. Its one thing tossing an old adapter in the bin, its entirely different when I need to pull out the tool bag and start re-terminating receptacles, or worrying that one of these things is really going to go bad and possibly create a fire hazard.
It's not a big deal to provide a USB model of your standard USB Decora duplex receptacle, I'll just base it on the T5632 (Leviton) and if people want something different they can replace the default model in the library that I provide.
As I was eating outing this evening with the wife I noticed along the bar a line of outlets (and even a couple switches) that were mounted horizontally rather than vertical. I will need to add in the first of the advanced options which allows the user to toggle between a vertical or horizontal mount, obviously vertical will be the default.
Added the advanced option which will allow for a horizontal mount of any receptacle:
First look at the the following:  GFCI, USB, Simplex, Horizontally mounted Duplex
I will also extend this same functionality to the switch module so that they can be mounted in any orientation.
Option for weatherproof GFCI added:
I haven't gotten every combination but I think I now have about 85% of the most commonly used configurations added in for outlets.  I will now return to the switch module and work that over for a while until it is also about 85-90% coverage.
I also still need to add in a completely new style: 240V
This will comprise single gang outlets for clothes dryers, welders, and ranges.
I've added in the option for 240V receptacles:
These are limited to single gang configurations as shown (2 gang electrical box).  They can be mounted either vertical or horizontal.  The annotation allows one to specify either a dryer (D) or range (R) outlet.
By default the color of the outlets is a dark brown (thermoplastic) but can be modified by the user as well as the wall plate material.
I was going to add in an option for a welder outlet but I'm not sure which outlet type is the most common for this application, it appear that the NEMA 6-50 is commonly used for welders but until I get more information or a direct request for this particular NEMA receptacle I will leave this one for now.
Dimensions for these outlets types are per Leviton's product lineup, as is the wall plate.  For now I've employed the standard 2-gang Carlon PVC box but for a heavier circuit like these I personally would probably go with a metal box and the appropriate mud ring and cable clamps.
https://www.hubbell.com/raco/en/Products/Electrical-Electronic/Boxes/4-in-Square-Boxes-Covers/8235/p/1670412#prod-resources-section
https://www.hubbell.com/raco/en/Products/Electrical-Electronic/Boxes/4-in-Square-Boxes-Covers/769/p/141876
A few more options for the switches module:
One of my favorite switches, the Trimatron.
I will provide the same 14-xx outlet in 30 and 50 amp without the dryer or range designation, for those applications that are something other than those two typical residential usages.
I was looking at Square D service panels (load centers) last night and I'm most familiar with their QO product, not a huge fan of the cheaper Homelite product line.  I can't seem to find any decent drawings or dimensions for these enclosures other than the overall size.  If anyone can direct me to a resource which will allow me to model these up with some accuracy I would like to add in a handful of service panels.
I'm probably not going to dive too deeply into the load center module right now, only providing a basic model and label, but eventually it would be nice if one could assign specific outlets, switch and light fixtures to a given circuit/circuit breaker.  There is a lot that can be done with this sort of thing.
For low voltage I am going to start with only one style for now and that is the Leviton Quickport system:
The advantage with this system in my opinion is that there will be less electrical boxes to install since you can get more than one outlet per box (max. is 6 ports for a single gang box).
My only problem now is how to show this type of port on the electrical plan.  Typically I would have a symbol for TV, Phone and/or Data.  However, what does one show when you have a situation like above where all three data types are compressed into one box.  Even worse, what if I have the 6 port version and have one phone jack, two CAT6 jacks, two coax jacks and a blank?
What is the preferred convention?  If there is one.
Additionally there is the 2-gang low voltage box (Carlon SC200AR) which can be fitted with a Quickport face plate and have a maximum of 12 separate ports, yikes.
I've also added in the RCA QuickPort by request.
You will be able to assign a unique QuickPort outlet to each port of the wall plate and also assign it its own unique color if you choose (this will be important for people who are color coding network jacks).
The updated toolbar:
I will leave it up to inquiring minds to figure out what all these icons mean. :)
The low voltage module is working pretty good now.  I just need to wrap up the 2D symbols and then we will see if I can put together a few typical load centers, and then its out to the public for some BETA testing.
A 2-gang, 12 port low voltage box is probably your worst case scenario:
Each port can be assigned one of the following:
- CAT6
- CAT5e
- COAX
- PHONE (RJ11)
- RCA (Audio/Video, gold plated)
- BLANK (Plastic Insert)
Additionally each port has its own unique material/color which by default is "White".  The faceplate can also be assigned a unique material/color.
Similar to other outlets the advanced options can be enabled which allows for vertical or horizontal mounting.
The number of possible QuickPorts is limited to the following:
1-Gang:  1, 2, 3, 4, 6
2-Gang:  8, 12
There are additional 2-Gang QuickPort wall plates that I have not added.  I will only add these if requested, since they are already covered by the 1-Gang option.
Various combinations of QuickPorts yields a number of possible 2D symbols:
I've tried to stay with conventional symbols as much as possible.  Please let me know what you think on this.
Tomorrow I will finish modeling up some typical load centers (breaker boxes) like the one below (200 Amp, 40 Spaces):
I'm not going to put any special logic into this module yet, just a simply positioning and selection.  However at some point it would be really cool to use the plugin to setup the various breakers and identify circuits as well as assign specific elements to a circuit.
For now three sizes of breaker components are provided and it is up to the user to manually configure their panel if they so choose to do so, otherwise is is more representational than anything else.
When it comes to setting the vertical height of the load center what is the method used to measure from the floor?  Center, Top or Bottom of the panel?
I will provide some common panel sizes (spaces):  24, 30, 40, 42, 54, and 60.
My breakers are based on the SquareD QO series as are my load centers however they are considerably simplified to maintain a low poly count.
Also for now I am only going to provide flush mount and not surface mount however I will probably enable both in the future.
https://3dwarehouse.sketchup.com/model/560f7404-63e8-4b7f-9920-eb0775ae5e34/Load-Center-Example
