Display Doors in Open State
Started by Stephan B, November 23, 2023, 08:05:35 PM
Stephan B
Is there an option to display doors in their open state?
I can obviously rotate the doors manually but regening any of those openings resets those doors.
I can probably add in a global or wall parameter which will regen the doors in their open state.  Typically people want the regen to put them back into the closed state.  I assume you are also aware of the opening tool which does this automatically for you.
Stephan B
A global and wall parameter property would be ideal.
I am aware of the Opening Tool which appears to give the ability to easily change door orientation and style but not sure on how to control showing a door as Open.
Stephan B
Did you manage to get around to adding an option to display doors in their open or closed states?
#4
The fourth icon from the left is the open/close tool:
The Opening Tool and Copy Opening Tool are on the Medeek Wall Tools II toolbar, they are something different.
Stephan B
Thank you. I had completely overlooked that tool which I guess was hiding in plane sigh  :o
There are quite a few tools and icons now.  Be sure to watch as many tutorial videos as you can, this will introduce to more of the tools and get you up to speed quicker.
