Version 0.9.9x - 12.01.2024
- Fixed a bug with the SUBTRACT_JOIST feature.
- Updated the algorithm for large span Open Joist floors.
Rather than insert a fictitious joist size that does not actually exist I decided to insert two short joist products back to back.  This seems to be the typical way to handle large span floors with this product (similar examples are given in the product literature).  This update was also by customer request.
The update to the SUBTRACT_JOIST feature is a critical update and I highly recommend updating to this latest version if you are using that functionality.  Since the boolean subtraction of the joists happens before the final floor assembly is created I had to account for the pre-transformation of the joist geometry and include this within the subtraction method.
Since I added the steel trusses I've had some call for steel decking.  I will look at adding in Verco Decking by Nucor, they have quite a complete product lineup for floors and roofs and it is well documented (so I can get it dimensionally accurate):
https://vercodeck.com/
The example shown is a W3-36 (FormLock) steel deck with 6.5 inches (total slab thickness) of concrete topping it.  If I provide the steel decking it makes sense to also provide an option for the concrete as well (at any thickness).
Are there any specifics decking types anyone would like to see added or additional options?  The decking will be able to rotated zero or ninety.  I will also provide an overhang parameter (and removal list) similar to the deck board options.
Version 0.9.9y - 12.04.2024
- Added Steel Decks w/ Concrete Slabs (Verco®): B-36, N3-32, W2-36, W3-36, SV, DV.
Version 0.9.9z - 12.07.2024
- Added Roof Sheathing within the Advanced Options.
- Added the following membrane types to the Roof Sheathing Module: BUR, MB, TPO, EPDM, PVC.
- Enabled multi-ply insulation with the roof sheathing module.
