In the Materials tab of the Global Settings you can switch between the more realistic textures/materials for lumber and pressure treated lumber:
I've updated the algorithm for non-orthogonal cut lumber so that even angled cuts will now show an end grain texture:
Goldplating for sure, but I think the proper material helps visualize better what is actually going on within the construction project.
First look at a mitered rim joist:
I know, no one builds it this way but I'm just covering all my bases.
I just need to test the sill plate algorithm tomorrow morning and I think we are ready for an initial BETA release.
waynehughes2
Nathan,
Good Morning, The floor extension looks great, cant wait to add it to the suite.
Thank You,
Wayne
First look at a mitered sill plate (pressure treated).
Notice that I don't have an end grain for LSL or PSL materials yet, not a huge deal but something to add to the todo list when things slow down a bit.
A reverse lapped rim joist with a regular lap on the sill plate:
I think I will forego the "solid" option for the rim and sill for now. If requested I will add it in but I don't consider it a priority right now.
Version 0.9.0 - 09.08.2024
- Created the Medeek Floor Plugin, utilizing SketchUp's Ruby API.
- Added the draw floor tool with the ability to create I-Joist and solid sawn (lumber) polygon shaped floors.
The Floor extension can be downloaded directly here:
http://design.medeek.com/calculator/sketchup/medeek_floor_ext.rbz
Note that this is a BETA release and does not include all of the future planned functionality (ie. openings, beams etc...)  I am only posting this release in a few select locations to allow power users to test it out first and help me further debug and refine it.  After approximately a week I will send out a notification to all users letting them know that the release is now publicly available. Hopefully in that time I can catch the most glaring bugs and issues so that my inbox does not become swamped.
Also all those who have been issued licenses in the last year or so will have their expiration update date of their license automatically renewed so that it will be active for one year starting from tomorrow's date (09/09/2025).
I desperately need to work on the hole tool and the floor covering tool. These two additions will make the plugin truly powerful. At this point it is not much better than the previous floor module in the Truss plugin (other than the ability to create polygon floor outlines).
There will be instances that hangers will be utilized however joists that are cut at diagonals will complicate the matter somewhat, I'm not even sure what hardware is available in that regard, I will have to spend some time researching that one and then coming up with a clever algorithm.
Please email me any feedback directly to nathan@medeek.com, any and all feedback is appreciated.
I've already updated the database so anyone who holds a license for the plugin has now had their license renewed for a full year.
The current todo list in no specific order:
1.)  Floor Coverings: Tile, Carpet, Hardwood etc...
2.)  Floor Openings:  Stairwell and Crawlspace or ladder access
3.)  In Floor Beams
4.)  Blocking:  Mid-span blocking, custom blocking, edge blocking
5.)  Ledgers:  customize each edge or side of an assembly with a custom ledger or rim joist setting.
6.)  Hardware:  Joist Hangers, Beam Hangers, diagonal bracing, deck holdowns
7.)  Railing: for decks
8.)  Custom Joist Doubling:  ability to double any number of joists in the array
9.)  Custom Joist Offset:  ability to offset any number of joists independently.
10)  Global Joist Offset
11.)  Max. Joist Span Indicator:  Engineering related
12.)  Diagonal deck boards
13.)  MPC Wood Floor Trusses
14.)  Steel Trusses (not high priority)
Feel free to help me add to this list.
Version 0.9.1 - 09.10.2024
- Enabled doubling of individual joists.
- Enabled offsetting of individual joists.
- Enabled global offsetting of joists.
- Added a duplicate floor check to the regen module for all floor types.
- Updated the javascript logic within the License tab of the Global Settings.
Version 0.9.2 - 09.11.2024
- Enabled a overhang for deck boards.
- Enabled a global offset for deck boards.
- Fixed a bug with floor presets.
Version 0.9.3 - 09.12.2024
- Fixed a critical bug in the Draw Floor menu.
- Added a status icon (Draw Mode: Polyline or Face) in upper right corner of the Draw Floor menu.
- Added the Draw Mode parameter to Floors tab of the Global Settings.
