Development and Updates for the Medeek Project Plugin
Started by Medeek, March 16, 2019, 10:51:52 AM
Version 1.0.8b - 02.13.2023
- Fixed a bug in the Estimating module for king stud quantities for windows and doors (metric units).
Version 1.0.9 - 03.10.2023
- Fixed a bug with the Trim 3 tool.
Version 1.1.0 - 07.01.2023
- Enabled FIS notation for dimensions in the General tab of the Global Settings.
- Added rafter lengths (with total length or minimum stock length) for gable and hip rafter roofs within the Medeek Estimator.
The rafter lengths are currently only available for imperial units.  If I get requests for this to be extended to metric units I will make this also available for metric units.
The rafter length in this case is actually the rafter length minus the overhang, so technically it is the length to the seat cut.
Version 1.1.1 - 07.30.2023
- Updated the estimating module to provide more granular data for wall top plates.
*Note:  If this updated version is installed then Version 3.2.3 of the Wall plugin is required in order to obtain wall top plate data.
This update per customer request.
Version 1.1.2 - 08.01.2023
- Updated the estimating module to provide location data (within a wall) for windows, doors, garage doors and in-wall columns.
Version 1.1.3 - 09.06.2023
- Updated the scene generator to include gable, shed and hip walls.
Version 1.1.4 - 07.01.2023
- Added complex rafter roofs within the Medeek Estimator.
- Added rafter labels (total length) for complex rafter roofs within the Medeek Estimator.
Version 1.1.5 - 01.23.2024
- Fixed a bug with the Extend Tool for groups (and components) that share the same definition.
Version 1.1.6 - 02.13.2024
- Added foundations within the Medeek Estimator: Slab-on-Grade, Slab, Stemwall, Grade Beam
There is still a lot more work to be done with adding all of the various hardware and items into the estimating for foundations.  This is just a start.
Version 1.1.7 - 02.17.2024
- Enabled custom rebar within the Medeek Estimator for Slab-on-Grade foundations
Per customer request.
Version 1.1.8 - 02.21.2024
- Updated custom rebar within the Medeek Estimator to include unit and total length.
- Added custom rebar within the Medeek Estimator for Slab, Stemwall and Grade Beam foundations.
- Updated the Medeek Estimator so that multi-ply (custom) Window and Door headers are properly called out and quantified.
- Added additional logic into the Medeek Estimator so that assemblies are ordered in the report logically by their assembly names.
Version 1.1.8b - 02.21.2024
- Fixed a bug in the ordering logic and a typo in the HTML preview menu.
#44
Version 1.1.9 - 03.22.2024
- Added a Weight Database to the Medeek Estimating Module.
- Enabled Weight Analysis to the Medeek Estimating Module for Rectangular Wall Panels.
- Fixed some minor bugs with the estimating module for wall panels.
