0 Members and 16 Guests are viewing this topic.
#780
Version 1.8.7 - 02.15.2021
- Added an option for the garage door track in the global settings.
Currently you cannot set this parameter per garage door, it can only be set globally (in the Garage Door tab).
I've had a number of people recently ask me for the ability to apply a wood grain texture to the lumber (ie. studs, plates, blocking, etc...)  This really isn't a big ask, so I am going to enable another couple parameters in the global settings (Material Tab) so that the user can apply a texture to lumber and pressure treated lumber.  Here is a first look at what that will look like (compare the wood grain wall to the solid colored wall):
I've tried to be very subtle with the wood grain texture so that it approximates my default lumber color but as you can see it is a slightly darker shade.  I'm not sure I am entirely happy with it yet but it is a start.
Comparison between the solid coloring and with the textures enabled (Lumber and PT Lumber):
I am quite happy with the way the pressure treated texture came out.
Version 1.8.8 - 02.17.2021
- Enabled options for wood grain texture for lumber and pressure treated lumber in the global settings.
#784
Version 1.8.9 - 02.22.2021
- Added a "Cedar Siding" built-in material (vertical) into the material library.
Version 1.9.0 - 02.24.2021
- Fixed a bug with the end stud height for Shed Walls with an "Inset Outside Corner".
mdkBIM Introduction (Japanese - 日本語)
A brief introduction of the mdkBIM bundle in Japanese.
mdkBIMバンドルの日本語での簡単な紹介です。
Version 1.9.1 - 02.27.2021
- Added one additional parameter to the "User Interface" section of the General tab of the global settings. This allows the customization (color) of the text of the HTML buttons.
This should also resolve the issue with the "white" text of the HTML buttons for MacOS.
First look at the new Custom Beam Library.  This will allow the user to create custom sized lumber, SCL or Timber beams:
Version 1.9.2 - 03.01.2021
- Added a Custom Beam Library/Manager in the Beams tab of the Global Settings.
- Enabled custom sizes for Sawn Lumber, Timber and SCL(PSL,LSL,LVL) beams.
This may seem like a rather minor update but there actually is quite a bit of code behind any of these custom libraries (within the global settings) and their menu systems, hence the three days of programming that was required.
Since glulam beams use a different sizing system I did not enable custom sizes for that beam type.  Additionally, all of the steel profiles are also quite a bit more complicated than a simple width x depth profile (rectangle) so they were also not included in this update.  If there are specific wide flange steel beam sizes etc... that you would like to see me add, please feel free to contact me.
Version 1.9.2b - 03.02.2021
- Fixed the framing bug with the top plates of rectangular walls so that they are not cut out when a tee intersection is created with non-rectangular walls.
Version 1.9.2c - 03.02.2021
- Fixed a bug with tee intersection blocking for gable, shed and hip walls.
Version 1.9.3 - 03.03.2021
- Added the ability to set the lower and upper wall heights of a shed wall within the edit menu.
Note that the relation between the upper and lower wall heights is a function of the wall length.  Therefore if you adjust the wall length the menu will adjust the upper wall height while maintaining the lower wall height.
Adjusting the lower wall height will cause the upper wall height to be calculated, based on the current length.
Adjusting the upper wall height will cause the lower wall height to be calculated, based on the current length.
#793
Version 1.9.4 - 03.05.2021
- Minor adjustment to the tee intersection algorithm (tee blocking and top plate cut outs) for all wall types.
This update addresses some issues with tee intersections and walls of differing heights.  I think this latest update is an improvement over the previous algorithm however I am still open to further tuning and refinement if there is further call for it.
As always I appreciate the constant feedback and testing being performed by the passionate and invested user base, without this valuable feedback the plugin(s) would certainly not have advanced as far as they have.
Version 1.9.5 - 03.07.2021
- Added an option for "Geometry Guides" at the start and end of all wall types.
- Added the "Start / End Marker" parameter to the General tab of the Global Settings.
The reason for this "Geometric Guide" feature is to help people understand how wall corners connect to each other (or don't connect).  You can turn this on in the global settings and it will help you understand how to connect your wall panels at the ends/corners.  I've had a lot of questions on wall corners lately so I hope this will help answer some of those questions.
The green circle is always created at the "start" of the wall panel and the red circle is always created at the "end" of the wall panel.  Notice that they are of different diameters so that when they overlay on top of each other it is obvious that they are concentric and therefore the walls are connected.
