Version 3.4.9 - 05.26.2024
- Enabled "vaulted" ceiling insulation for gable rafter roofs (symmetric and asymmetric): Batt, Blown-in.
- Added "vaulted" ceiling gypsum to gable rafter roofs.
- Enabled "flat" ceiling gypsum for gable rafter roofs with ceiling joists option enabled.
Version 3.5.0 - 05.26.2024
- Enabled "flat" ceiling gypsum for dutch gable rafter roofs.
- Enabled "flat" ceiling gypsum for hip rafter roofs.
- Fixed a bug with the global settings for rafter and truss roofs when the layer/tags option is turned off.
**CRITICAL BUG FIX!**
Version 3.4.7 introduced a bug for both rafter and truss roofs when the layers/tags option is turned off.  This release fixes that bug.  I highly recommend that everyone download this latest update to correct this bug.
Version 3.5.1 - 05.28.2024
  • Enabled ceiling insulation for gambrel attic and attic trusses: Batt, Blown-in.
  • Enabled ceiling insulation for scissor trusses: Batt, Blown-in.
Version 3.5.2 - 05.30.2024
- Enabled ceiling insulation for floor trusses: Batt, Blown-in.
- Enabled ceiling insulation for I-Joist and Lumber floors: Batt, Blown-in.
- Fixed a bug with ceiling gypsum for inset floors (I-joist and Lumber).
- Fixed a minor bug with joist hangers for common lumber sizes for inset floors.
Honestly I didn't want to spend too much time updating this module since the new Floor plugin will supersede it, however since I do intend on retaining it within the Truss plugin for the foreseeable future, I thought it best to bring it up to speed with the other truss assemblies, and add the insulation option.
Some of these updates seem small now and very incremental however they all take time and energy and they usually involve fairly tedious updates to the attribute library code and the HTML menus.
The Truss plugin overall probably still has the most work that needs to be done of all the plugins.  Compared to the Wall plugin this plugin has many partially finished tools and features and still certain trusses that are missing advanced options.  The work will go on.
Version 3.5.3 - 06.09.2024
- Enabled a feature to selectively remove specific trusses from floor truss assemblies.
- Enabled a feature to selectively remove specific joists from I-joist and lumber floor assemblies.
Version 3.5.4 - 06.15.2024
- Fixed a bug introduced in Version 3.4.7 for all rafter and truss roofs.
!! Critical Bug Fix !!
Note that this bug only reveals itself if you have the sub-fascia for the truss or rafter roof turned off.  This bug applies to both truss and rafter roofs (gable).
Version 3.5.5 - 06.22.2024
- Fixed a bug introduced in Version 3.4.7 for all rafter and truss roofs (when adv. roof options disabled).
!! **Critical Bug Fix** !!
This bug only reveals itself if you turn off the advanced roof options.  The bug applies to truss and rafter roofs.  I highly recommend updating to this latest version.
The new Rafter Roof menu should be a bit more visual and intuitive for selecting the appropriate roof type:
Version 3.5.6 - 07.03.2024
- Enabled a graphical user interface for Rafter Roof selection.
- Enabled a graphical user interface for Floor selection.
- Fixed a bug introduced in Version 3.5.3 for all I-joist, lumber and truss floors (when adv. floor options disabled).
Version 3.5.7 - 07.05.2024
- Fixed a bug for all rafter roofs that have glulam beams.
Version 3.5.8 - 07.12.2024
- Enabled the "Edit Roof Assembly" function for gable rafter roofs with glulam beams (imperial and metric units).
- Enabled the "Edit Roof Assembly" function for I-joist rafter roofs with glulam beams (imperial and metric units).
- Enabled the "Edit Roof Assembly" function for I-joist rafter roofs with dual glulam beams (imperial and metric units).
- Added BCI, LPI, Red-I and PKI I-joists to the rafter roof module (glulam beam and dual glulam beam roofs).
Version 3.5.9 - 07.17.2024
- Added a "Rafter Roof" tab to the Global Settings.
- Added Sub-Fascia parameters to the Rafter Roof and Complex Roof tabs of the Global Settings.
Version 3.6.0 - 07.18.2024
- Added rake parameters to the dutch gable rafter roof edit menu.
- Fixed a bug with the hip and dutch gable advanced options module (when sheathing is disabled).
Version 3.6.1 - 07.19.2024
- Added Soffit Cut within Advanced Options for Complex Rafter Roofs.
- Fixed a **critical bug** with the complex roof module.
My youngest daughters latest creation. Maybe I spend too much time working on these plugins.
