0 Members and 11 Guests are viewing this topic.
Version 0.9.9q - 11.10.2024
- Added a perimeter offset parameter within the edit menu for floors drawn in "Wall" mode.
- Added two "Wall Mode Options" to the Floors tab of the global settings: Perimeter Offset and Move Walls.
- Connected the "Move Floor Edge" tool to the Medeek Wall API so that moving floor edges (Wall Mode Only) can also move walls.
- Updated the Draw Flooring tool so that floor coverings can be applied to slabs, slab-on-grade foundations and floor trusses.
Version 0.9.9r - 11.10.2024
  • Added a "Sheathing" tab to the Global Settings.
  • Added floor sheathing and ceiling gypsum parameters to the Sheathing tab of the Global Settings.
  • Fixed a minor bug with the perimeter offset (wall mode) in the floor draw menu.
Two releases in one day, I'm running out of letters.
**Tutorial 18** - Moving Walls with Floors (9:17 min.)
First look at a TRIFORCE Open Joist floor:
https://www.openjoisttriforce.com/
There has been some call for this product line so I am working on the algorithms so that it can be configured properly.  It is a bit more complicated due to the directional nature of its trimming panel (only one end can be trimmed).
Version 0.9.9s - 11.13.2024
- Added the "Open Joist" floor family.
- Added the following TriForce Open Joists: OJ3-11.875, OJ4-11.875.
First look at some RedBuilt (Red-W) open web floor trusses:
It isn't too big of a stretch to also include some steel open web trusses/joists:
First look at a Nucor/Vulcraft (K Series) steel floor truss (top chord bearing):
Currently these are defined by 13 parameters but I may need an additional four in order to specify a top chord extension and the bottom chord extension on both ends.
Various configurations and example usages of top-bottom and bottom-top for open web (Redbuilt) and steel trusses (K Series):
Version 0.9.9t - 11.19.2024
- Added the "Open Web" floor family (RedBuilt™: Red-L, Red-M, Red-S, Red-M, Red-H).
- Added the following TriForce Open Joists: OJ3-14, OJ4-14, OJ3-16, OJ4-16.
- Added the "Steel Truss" floor family (Nucor®: K-Series).
- Added a removal parameter for sill plates.
Version 0.9.9u - 11.23.2024
- Added the "CFS" floor family: ClarkDietrich, JoistRite and TotalJoist.
- Added additional logic for non-standard joist sizes for Open Joists (TriForce).
- Addressed some minor bugs with metal bracing and other advanced options for top chord bearing trusses (Open Web and Steel).
- Added a built-in steel material option for rim joists.
Let me know on any other floor framing system(s) that I should add.
Version 0.9.9v - 11.24.2024
- Added a "Web Shield" option for PinkWood (PKI) I-Joists.
- Fixed multiple bugs with the floor preset module.
- Fixed a bug related to metric units within the edit menu.
- Updated (Manufacturers: LP and PinkWood) links on the Floor plugin website.
They now have this new option called "WebShield":
I have been giving MPC floor trusses some more thought since this is the last big floor system type that is not part of the plugin yet. The example I've shown below was created with the existing floor truss module of the Truss plugin. I created three separate assemblies to give me the geometry needed to end up with this final model (some manual editing required, but doable in about 1-2 minutes). The common trusses themselves are not too much trouble the algorithm already exists for their geometry and placement. However I will need to come up with some new logic for the gable (ladder) trusses shown:
app.sketchup.com/app?3dwid=2beabd1f-fe7e-4f68-9d28-1063258859a0
Version 0.9.9w - 11.25.2024 thru 11.29.2024
- Fixed multiple bugs with metric units within the attribute libraries and edit menu.
- Fixed a bug with offset joists and metal bracing, blocking and insulation.
Tutorial 19 - Steel Trusses and Joists (18:19 min.)
