Author Topic: Development and Updates for the Medeek Foundation Plugin  (Read 102053 times)
« Reply #240 on: March 25, 2021, 07:15:52 am »
Version 1.6.9 - 03.25.2021
- Fixed a bug with footing offsets when a (polyline) stemwall terminates non-orthogonally.
« Reply #241 on: March 26, 2021, 09:37:59 am »
Version 1.6.9b - 03.26.2021
- Fixed a bug with footing extensions (polyline stemwalls) for SketchUp Pro 2021.
- Enabled hidden edges for polyline stemwalls that terminate non-orthogonally.
« Reply #242 on: May 08, 2021, 07:23:28 pm »
First look at a hole cut using the new SUBTRACT keyword system:
Now I just need to set this up for the other various foundation types (ie. stemwall, stemwall steps, strip footings etc...)
« Reply #243 on: May 09, 2021, 05:40:00 am »
Version 1.7.0 - 05.09.2021
- Sub-groups within foundations and footings can be made persistent and "subtractive" by naming these groups to (subtract1, subtract2, subtract3, etc...)
Interestingly the code to make this happen was staring me in the face for months.  I essentially took the "roof connections" complex roof module, changed up the logic slightly, simplified it, and arrived at this new feature/ability.
Notice that the subtractive groups cut through the rebar as well as the concrete.  Certain other elements such as anchor bolts (groups within groups) are not removed.  I may need to give this some additional consideration.
I guess we need to make this new feature available with the Truss plugin as well now.
« Reply #244 on: May 09, 2021, 12:51:23 pm »
Version 1.7.0b - 05.09.2021
- Components within foundations can also be made persistent and "subtractive" by naming the component instance to (subtract1, subtract2, subtract3, etc...)
« Reply #245 on: May 19, 2021, 04:39:46 pm »
Version 1.7.1 - 05.20.2021
- Fixed a bug with subbase and slab insulation options for slab-on-grade foundations.
« Reply #246 on: June 03, 2021, 01:29:50 pm »
Version 1.7.2 - 06.03.2021
« Reply #247 on: June 12, 2021, 10:57:57 am »
Version 1.7.3 - 06.12.2021
- Added a "Regen" context menu item for the following foundation assemblies: Polyline Stemwall, Strip Footing, Interior Bearing.
« Reply #248 on: July 10, 2021, 01:37:57 pm »
Version 1.7.4 - 07.10.2021
- Enabled subscription and permanent licensing.
- The License tab of the Global Settings now displays the license type.
« Reply #249 on: August 04, 2021, 04:02:13 am »
Version 1.7.5 - 08.04.2021
- Fixed a bug with the stemwall blockout tool.
« Reply #250 on: September 09, 2021, 01:57:16 pm »
Tutorial 10 - Subtractive Geometry (15:45 min.)
« Reply #251 on: September 14, 2021, 02:55:08 am »
Version 1.7.6 - 09.14.2021
- Added an ICF option for polyline stemwalls.
- Added an ICF layer in the Global Settings under the "Layers" tab.
- Fixed a critical bug with custom materials that was caused by the change in the location of the plugin's data sub-folder.
https://3dwarehouse.sketchup.com/model/0a683d20-7115-491b-afc6-3578f584c5ae/ICF-Stemwall-Foundation
« Reply #252 on: September 18, 2021, 10:10:15 am »
Version 1.7.7 - 09.18.2021
- Added an ICF option for stemwall steps.
« Reply #253 on: September 18, 2021, 08:22:32 am »
I've been thinking about adding in a Door and Window module to the polyline stemwalls.  However, I'm not very familiar with what is common practice as far window and door bucks go.
Any feedback or drawings/details would be greatly appreciated.
« Last Edit: September 18, 2021, 08:50:27 am by Medeek »
« Reply #254 on: September 18, 2021, 10:30:49 pm »
Now that I'm on the subject of windows it may also be useful to add in some sort of window well feature:
Window Well Options:
Type: Steel
Shape: Rectangle, Arc, Trapezoid
Width:
Projection:
Depth:
Radius:
Vertical Offset:
