SketchUp Extensions > Medeek Wall Plugin
(1/174) > >>
Medeek:
Started to put the Wall Plugin together in earnest today.  A lot of competing interests so I'm still not sure on the date of first release yet, but at least I'm putting something together now.
For the Imperial Version the First and Second Menu Items (Ext. Wall Type) are currently:
First Menu:
1.)  Wall Mode:  Line, Polyline
2.)  Wall Type:  Exterior, Interior
3.)  Wall Justification:  Front, Center, Back
4.)  Wall Height (in.):  97
5.)  Wall Header Height (in.):  80
6.)  Stud Size:  2x2, 2x4, 2x6, 2x8, 2x10, 2x12
7.)  Stud Spacing (in.):  12,16,19.2,24,32,48
8.)  Stud Direction: Left, Right
9.)  Corner Offset (in.): 0
10.)  Top Plate:  1,2,3
11.)  Top Plate Thickness (in.): 1.5
12.)  Bottom Plate:  1,2,3
13.)  Bottom Plate Thickness (in.): 1.5
14.)  Adv. Wall Options: YES,NO
Second Menu (Adv. Wall Options):
1.)  Wall Sheathing: YES,NO
2.)  Sheathing Thickness:  3/8,7/16,15/32,1/2,19/32,5/8,23/32,3/4
3.)  Wall Cladding:  YES,NO
4.)  Cladding Thickness:  3/8,7/16,15/32,1/2,19/32,5/8,23/32,3/4
5.)  Wall Gypsum:  YES,NO
6.)  Gypsum Thickness:  1/4,3/8,1/2,5/8
I will start with the (single wall) line mode first and then progress to the polyline once I have the basic system working.  Then the addition of doors and windows and advanced options which will automatically insert doors and windows into the openings.
I've been thinking about brick facade and I'm not entirely sure how I'm going to incorporate this into the plugin yet.  Typical air gap is 1":
A 5.5" thick stud wall with 1/2" sheathing and a 1" air gap with 3.5" thick brick fits on a 10" stemwall with a 1/2" overhang of the brick.  Does anyone have any wall details/sections that they would like to see implemented in the plugin?
Here is the same wall but with a 4" x 6" brick ledge:
Notice the APA detail the brick ledge does not project below the structural sheathing, this probably makes more sense since you probably don't want the butt end of the sheathing sitting against the concrete and absorbing moisture, even though there usually will be a foam strip between the sill plate and the concrete.
I've also seen details where the sheathing laps down over the brick ledge about a 1/2", this probably makes sense in helping to keep the bugs out but then it puts the sheathing into more direct contact with the concrete.  More discussion on this subject is warranted.  I've never actually had to provide a wall detail for brick since most of the construction locally is with hardi-plank siding so my experience with brick is theoretical at best.
Medeek:
Here is the same brick wall but with the sheathing lapping the brick ledge and the foam sill strip shown:
Medeek:
The initial toolbar:
I may add a couple more icons for editing and deleting openings (windows,doors).
Medeek:
This toolbar will be for light frame wood walls.  My plan is to have another toolbar (in gray steel blue color) very similar to this one for cold frame steel walls.  This will allow for the user to turn on and turn off which ever tools bars they need without having to clutter just one toolbar up with too many options that may or may not apply to that wall type.  Similarly a separate toolbar for CMU walls as I get to that.
I'm sure there are other wall types that will come up but initially I plan on focusing on the standard wool wall and perfecting that as much as possible.
Things will get complicated with the cladding options (ie. siding, brick facade, cultured stone, stucco and river rock) especially where they are partial wall heights and other interesting features like trim, corner treatments (Quoin), lintels, keystones and arched window and doorways.  Even the typical siding products like hardi-plank will have a number of cladding and trim options.
Here is a typical oval window that the plugin should be able to generate:
The there is the interior details (trim) of windows and doors that also should be provided by the plugin as an option:
Most houses I've lived in had only had the GWB surrounding the windows but at the minimum the doors usually has some form of casing or surround.  Integral to this is the baseboard and the optional crown molding and wainscoting.
Medeek:
I've thought about using the Profile Builder method of pushing assembly along a path but unfortunately that only works well up to a point. When you start throwing complex openings into the mix things become much more complicated. This plugin may shape up to be even more challenging than the Truss Plugin, I guess will see how far I can take it.
As part of the door openings module there will also be interior vs. exterior as well as garage door openings. The framing aspect of the plugin should also be able to create portal frames with solid sawn and glulam headers.
Navigation
[0] Message Index
[#] Next page
Go to full version
