Author Topic: Development and Updates for the Medeek Wall Plugin  (Read 218388 times)
0 Members and 5 Guests are viewing this topic.
« Reply #825 on: April 26, 2021, 08:37:01 am »
The insulation algorithm is now working correctly with trapezoid windows:
« Reply #826 on: April 26, 2021, 04:07:20 pm »
First look at some trapezoid picture windows:
« Reply #827 on: April 27, 2021, 04:22:20 am »
Only the “perimeter” grille style needed modification for the trapezoid window:
« Reply #828 on: April 27, 2021, 07:24:01 am »
First look at exterior trim with trapezoid windows:
The good news is that the various window modules (eg. window installation, trim, casing etc...) are independent of the wall type so enabling trapezoid windows for the various gable wall types should now proceed relatively quickly.
« Reply #829 on: April 27, 2021, 01:36:50 pm »
First look at interior casing with trapezoid windows (Style A, B, and C):
« Reply #830 on: April 28, 2021, 10:14:04 am »
First look at trapezoid windows within a gable wall:
Notice how the right most window has it's header pushed up against the top plate (no cripples or insulation installed).  To achieve this one must adjust the header height until it is at the correct height since "Raised" headers are not currrently enabled for gable, shed or hip walls.
« Reply #831 on: April 28, 2021, 06:31:44 pm »
Version 2.0.6 - 04.29.2021
- Added trapezoid windows to the window draw and edit menus for all wall types: rectangular, gable, shed and hip.
https://3dwarehouse.sketchup.com/model/49ff1887-d503-4b19-b9a4-2b30c1487c29/Trapezoid-Windows
« Reply #832 on: April 29, 2021, 02:58:09 pm »
Version 2.0.6b - 04.29.2021
- Added triangle windows to the window draw and edit menus for all wall types: rectangular, gable, shed and hip.
- Added the "Total Window Height" callout to the trapezoid window's section of the window draw and edit menus.
« Reply #833 on: April 30, 2021, 08:53:58 am »
Version 2.0.6c - 04.30.2021
- Fixed a critical bug with the shutter module.
***** CRITICAL FIX *****
If you downloaded and installed Version 2.0.6b then you will want to immediately uninstall and download Version 2.0.6c.  The previous version introduced a minor bug to the shutter module which will causes errors with any windows that have shutters.  Installation of Version 2.0.6c is highly recommended.
« Reply #834 on: April 30, 2021, 01:13:24 pm »
I am very excited with the solid progress made on the Wall plugin these last few weeks and months, especially with the recent addition of both trapezoid and triangular windows.  In light of the recent progress and in hopes of allowing more users access to the features of the plugins  I will be immediately offering 40% off of the mdkBIM bundle price using the coupon code MOTHERSDAY21. (May 1, 2021 thru May 10, 2021).
This will reduce the bundle price from $170.00 USD to $102.00 USD. This promo code does not apply to any of the extensions purchased separately or to the electrical plugin. The offer ends on May 10th and no rain checks will issued thereafter.
« Last Edit: April 30, 2021, 01:18:33 pm by Medeek »
« Reply #835 on: May 01, 2021, 08:55:30 am »
Version 2.0.7 - 05.01.2021
- Fixed a bug with the tee intersection gypsum cutout algorithm for shed walls.
A similar fix will probably be required for gable and hips walls but I haven't dug into that section of the code just yet.
« Reply #836 on: May 01, 2021, 02:50:43 pm »
Version 2.0.7b - 05.01.2021
- Fixed a bug with the tee intersection gypsum cutout algorithm for gable and hip walls.
« Reply #837 on: May 03, 2021, 06:52:34 am »
Here is an interesting framing situation.  You have two internal walls that tee into a wall which has a pocket door that bisects the tee:
Overall no major problems the three walls can be configured correctly with "tee" intersections and the offset can be set to 1.75" for the two tee walls so that they meet properly at the top plate.
The only issue is the that the gypsum backer studs are drawn full length and should be truncated at the header (hence the clash).  The offending gypsum backer is colored red in the screenshot.
The manual work around is to use the Trim Tool (Medeek Truss) and quickly trim the gypsum backers.  I will have to examine this situation further and see if some additional logic can remedy this clash.  This is not a huge deal breaker/ hot item in my opinion but it is a special framing case that needs a second look.
The other obvious (simple) solution is to turn off the tee intersection backers in the global settings but this is really not a good option since it will disable the gypsum backers for all the walls in the model, not just this one.
https://3dwarehouse.sketchup.com/model/ea326739-09ef-4bc6-98d7-d448ee3055c4/Pocket-Door-with-Tee-Intersections?tab=general
« Reply #838 on: May 03, 2021, 01:47:51 pm »
First look at "Pentagon" windows:
Note that if one sets the window height to zero you can also achieve an isosceles or equilateral triangle window (the degenerate cases).
Since I'm fresh on windows right now I thought that it might be the opportune time to add in the pentagon picture window as well, one less monkey on my back.  The only other significant window missing is probably the quarter circle.
« Reply #839 on: May 04, 2021, 01:37:14 am »
Pentagon window with "Perimeter" style grill:
