Author Topic: Development and Updates for the Medeek Floor Plugin  (Read 5591 times)
« on: December 06, 2019, 12:41:01 am »
I am starting this new discussion thread as a fork from the Medeek Truss Plugin thread since the Medeek Floor extension will now become a stand alone extension/plugin.
Its icon(s) will be:
This new plugin will ultimately replace the floor joist/truss module currently found in the truss plugin.
Similar to the complex roof module the designer will be able to create any polygon shaped floor outline, and edit the shape by moving/adjusting the edges.
There will be a tool for creating and editing holes within the floor.
There will also be a tool for creating polygon shaped floor coverings (ie. carpet, tile, wood, pergo etc...) with an associated label and optional sqft callout.  These floor coverings will be situated on top of the sub-floor and can be individually edited.
Eventually the floor assemblies will also be integrated with the estimating module currently found in the wall plugin (this will be moved to the Medeek Project extension in the near future).
There will also be an option for gypsum on the underside of the floor with a user editable offset (ie. 5.5 inches).
I have a few more ideas for this new extension but I would be interested in hearing what ideas you might have that would make this extension have even more utility for you and your workflow.
« Last Edit: December 06, 2019, 12:50:36 am by Medeek »
Re: Development and Updates for the Medeek Floor Plugin
« Reply #1 on: December 08, 2019, 04:29:36 am »
Per discussion and input this morning from a valued mentor/adviser I've added a few more items to the list:
1.)  A tool for adding in mid-span blocking where the user can specify a location, extant and type of blocking.
2.)  A blocking tool (also need this for the wall plugin) which will allow the user to create special blocking for point load conditions etc...
3.)  An in-floor beam tool similar to the in-column wall tool of the wall plugin.  The wall plugin already has a beam tool but this is for stand alone beams.
4.)  Option for cavity insulation within the floor assembly, however an additional parameter which allows the control of the batt thickness since it may not be the same depth as the floor cavity.
5.)  With the floor covering tool provide a vertical offset parameter.  I may also set it up so that multiple layers are possible.
« Reply #2 on: December 09, 2019, 01:09:06 pm »
I've been thinking about this plugin some more as I've been occupied with upgrading the javascript/ruby interactions within the wall plugin.
Some floor framing plans are very simple, while others are considerably more complex.
I need to make the plugin as flexible as possible so it can accommodate the more complex floor variants.
One issue I'm trying to address is how to best handle floor plans that have floor joists running in different directions within a single floor plan/assembly.
My proposed solution is to limit the direction of the floor joists in any given assembly to one direction.  Then to allow for a complex floor assemblies I will need a tool to suppress the rimboard along any given edge of the floor assembly.  This will then allow for the butting up of floor assemblies next to each other to get the desired floor framing layout.
This particular edge tool will have three options for any given edge of the floor assembly:  rimboard, no rimboard, or ledger.
« Reply #3 on: December 26, 2019, 04:10:01 pm »
First look at the main toolbar for the plugin:
1.) Draw Floor
2.) Edit Floor
3.) Move Floor Edge
4.) Edit Rim Joist
5.) Engineering
6.) Global Settings
Most of these tools are fairly self explanatory, number 4 is probably the most interesting.  I will allow the user to customize each rim joist per floor edge (if desired), or remove it entirely.  This will come in useful where there are multiple floor assemblies abutted next to each other.
There will also be additional context menu tools (ie. regen floor assembly).  One context menu tool I am thinking about adding in is a way to select a given edge as the starting point for the floor joists/trusses.  This will allow the direction and spacing of the floor joists to be aligned to any edge along the floor outline.
There will need to be another completely separate toolbar and tools that deals specifically with holes cut into the floor.
Lots of little details to still work out and even though much of the code base can be recycled from the other plugins there is still a lot of work involved to produce a completely new plugin with the capabilities that I envision for this new architectural tool.
« Reply #4 on: December 27, 2019, 07:50:50 pm »
First look at the floor opening toolbar:
1.)  Draw Floor Opening
2.)  Move Floor Opening
3.)  Edit Floor Opening
4.)  Delete Floor Opening
« Reply #5 on: December 28, 2019, 04:42:20 am »
First look at the floor covering toolbar:
1.)  Draw Floor Covering
2.)  Move Floor Covering
3.)  Edit Floor Covering
4.)  Delete Floor Covering
The colors are a little bright for me, I may have to subdue them a bit to get the right look.
« Reply #6 on: December 28, 2019, 05:40:39 am »
First look at the floor beam toolbar:
1.)  Draw Floor Beam
2.)  Move Floor Beam
3.)  Edit Floor Beam
4.)  Delete Floor Beam
If the floor beams align with the joists/trusses things are fairly straightforward, however if the in-floor beams are perpendicular or oblique to the joists this becomes a bit more interesting.
I will have to give some serious thought to this module in order to make it as flexible as possible.
« Reply #7 on: December 28, 2019, 05:53:24 am »
So far this is a total of four toolbars.  I may need one additional toolbar for misc. items such as mid-span blocking and/or a blocking tool, but I can address these items later once I have established the core functionality of the plugin.
Am I missing anything obvious?
« Reply #8 on: December 31, 2019, 07:19:15 am »
For the floor covering module I think an option for 2 or 3 layers should be sufficient for most cases:
In this case I am modeling/representing the carpet and its pad.
Tile floors usually require some time of cement board underlayment.
Pergo and hardwood floors may also have an underlayment of some type or another.
Openings cut in the floor assembly will also cut through the floor coverings if they intersect.  This will allow for interior holes within a floor covering.
« Reply #9 on: May 14, 2020, 06:38:18 pm »
Development was paused on this extension at the beginning of March, I apologize for the delay in its initial BETA release.  Development will begin in earnest again starting June 1st, with an estimated ETA of Sept. 1st.
Offline mrramsey
  • Newbie
« Reply #10 on: March 21, 2021, 12:42:21 am »
Will tHIs plug-in be part of the BIM package?
« Reply #11 on: March 21, 2021, 05:07:10 am »
Yes, it will be the 4th plugin within the mdkBIM bundle.
