0 Members and 8 Guests are viewing this topic.
Version 1.3.2 - 07.11.2021
- Enabled subscription and permanent licensing.
- The License tab of the Global Settings now displays the license type.
Version 1.3.3 - 01.11.2023
- Enabled layer control integration with the Medeek Project extension.
Version 1.3.4 - 06.13.2023
- Enabled switches, outlets and lights to be inserted into "component" walls.
Previously electrical fixtures could only be inserted into walls that were "groups", with this update the wall assemblies can be either groups or components.
I will still need to update the other misc. electrical fixtures (ie. panels, low voltage, safety, heaters, vents, low voltage panels etc...)
Version 1.3.4b - 06.15.2023
- Enabled all other electrical fixtures for "component" walls.
Version 1.3.5 - 09.29.2023
- Added six additional dimmer switch combinations.
Version 1.3.6 - 10.04.2023
- Added an offset parameter (advanced options) for outlets which allows the symbol and label to be offset from the wall.
- Added two additional advanced parameters for vertically offsetting text and symbols for switches and outlets.
The text and symbol vertical offsets are driven by the global settings however these two parameters can now be adjusted separately for each individual outlet or switch.
Version 1.3.7 - 10.14.2023
- Added four timer switch combinations (Leviton VPT24-1PZ).
Added per customer request.
Version 1.3.8 - 11.22.2023
- Added two additional parameters for annotation formatting.
- Added the "Regen Electrical" function to the primary toolbar, enabled regeneration for all electrical fixtures.
- Moved the "Draw Safety Device" tool to the secondary toolbar.
Version 1.3.8b - 11.23.2023
- Added the "Symbol Text Scale" parameter for scaling superscript of 2D electrical symbols.
With this update one can scale the 2D symbol superscript of the electrical symbols and make them more visible and legible when exporting to Layout, PDFs or paper.
