Size: 5.125 x 12
Design Span (L): 29.58 ft.
Clear Span: 29.17 ft.
Total Span: 30.00 ft.
Bearing (lb): 5 in.
Selfweight: 426.6 lbs
Dist. Selfweight: 14.42 plf
Total Weight: 432.6 lbs
CV Volume Factor 0.966b - - - - -
Beam Design 2026A99
4/2/2026 1
b = 5.125 in.
Beam Design 2026A99
4/2/2026 2
Volumetotal = N[A x (L + lb)] = 1 x [61.50 x (355.00 + 5)] x (12 in./ft.)3 = 12.81 ft3
Volumespan = N[A x L] = 1 x [61.50 x 355.00] x (12 in./ft.)3 = 12.63 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 12.81 = 432.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 12.63 = 426.6 lbs
  ws = 14.42 plf
29.58 ft.
29.17 ft.
30.00 ft.
2841.25 lbs
2841.25 lbs
Beam Design 2026A99
4/2/2026 3
CV = = 0.966
CV = 0.966 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.966) = 2667.0 psi
fb = = 2021.6 psi
 fb = 2021.6 psi < Fbx' = 2667.0 psi  (CSI = 0.76)   ➜  OK
Beam Design 2026A99
4/2/2026 4
fv* = = 63.72 psi
 fv* = 63.72 psi < Fvx' = 304.75 psi  (CSI = 0.21)   ➜  OK
fv = = 68.34 psi
 fv = 68.34 psi < Fvx' = 304.75 psi  (CSI = 0.22)   ➜  OK
Beam Design 2026A99
4/2/2026 5
ΔLL = = 1.30 in.
(L/d)LL = 355.00 / 1.30 = 274
 ΔLL = 1.30 in = L/274 > L/360   ➜  NG
ΔTL = = 2.46 in.
(L/d)TL = 355.00 / 2.46 = 144
 ΔTL = 2.46 in = L/144 > L/240   ➜  NG
Ab = b x lb = 5.125 x 5 = 25.63 in2
fc⊥ = = 110.9 psi
 fc⊥ = 110.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.17)   ➜  OK
Beam Design 2026A99
4/2/2026 6
