Grade: DF SS
Design Span (L): 15.25 ft.
Clear Span: 15.00 ft.
Total Span: 15.50 ft.
Quantity (N): 4
Live Load: 60 plf
Dead Load: 360 plf
Selfweight: 244.5 lbs
Dist. Selfweight: 16.03 plf
Total Weight: 248.5 lbs
Incised Lumber: Yes
Beam Design 2026A94
3/30/2026 1
Beam Design 2026A94
3/30/2026 2
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (183.00 + 3)] x (12 in./ft.)3 = 7.27 ft3
Volumespan = N[A x L] = 4 x [16.88 x 183.00] x (12 in./ft.)3 = 7.15 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 7.27 = 248.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 7.15 = 244.5 lbs
60 plf
360 plf
ws = 16.03 plf
15.25 ft.
15.00 ft.
15.50 ft.
3379.26 lbs
3379.26 lbs
Beam Design 2026A94
3/30/2026 3
Fbx' = (1500)(1.15)(1)(1)(1)(1)(0.8)(1) = 1380.0 psi
fb = = 1201.8 psi
 fb = 1201.8 psi < Fbx' = 1380.0 psi  (CSI = 0.87)   ➜  OK
Beam Design 2026A94
3/30/2026 4
Fvx' = (180)(1.15)(1)(1)(0.8) = 165.60 psi
fv* = = 64.80 psi
 fv* = 64.80 psi < Fvx' = 165.60 psi  (CSI = 0.39)   ➜  OK
fv = = 73.88 psi
 fv = 73.88 psi < Fvx' = 165.60 psi  (CSI = 0.45)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1900000(1)(1)(0.95) = 1805000 psi
Beam Design 2026A94
3/30/2026 5
ΔLL = = 0.06 in.
(L/d)LL = 183.00 / 0.06 = 3221
 ΔLL = 0.06 in = L/3221 < L/360   ➜  OK
ΔTL = = 0.41 in.
(L/d)TL = 183.00 / 0.41 = 443
 ΔTL = 0.41 in = L/443 < L/240   ➜  OK
fc⊥ = = 187.7 psi
 fc⊥ = 187.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.30)   ➜  OK
Beam Design 2026A94
3/30/2026 6
