Design Span (L): 4.33 ft.
Clear Span: 4.17 ft.
Total Span: 4.50 ft.
Bearing (lb): 2 in.
Live Load: 133 plf
Dead Load: 67 plf
Selfweight: 9.3 lbs
Dist. Selfweight: 2.14 plf
Total Weight: 9.6 lbs
Load Duration: 2.00
CD Load Duration Factor 2.00 2.00 2.00 2.00 - -
Beam Design 2026A88
3/27/2026 1
Beam Design 2026A88
3/27/2026 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (52.00 + 2)] x (12 in./ft.)3 = 0.26 ft3
Volumespan = N[A x L] = 1 x [8.25 x 52.00] x (12 in./ft.)3 = 0.25 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.26 = 9.6 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.25 = 9.3 lbs
Distributed Self Weight (ws) = = 2.14 plf
133 plf
67 plf
ws = 2.14 plf
4.33 ft.
4.17 ft.
4.50 ft.
454.78 lbs
454.78 lbs
Beam Design 2026A88
3/27/2026 3
Fbx' = (1000)(2.00)(1)(1)(1)(1)(1)(1) = 2000.0 psi
fb = = 752.8 psi
 fb = 752.8 psi < Fbx' = 2000.0 psi  (CSI = 0.38)   ➜  OK
Beam Design 2026A88
3/27/2026 4
Fvx' = (175)(2.00)(1)(1)(1) = 350.00 psi
fv* = = 62.78 psi
 fv* = 62.78 psi < Fvx' = 350.00 psi  (CSI = 0.18)   ➜  OK
fv = = 79.62 psi
 fv = 79.62 psi < Fvx' = 350.00 psi  (CSI = 0.23)   ➜  OK
Beam Design 2026A88
3/27/2026 5
ΔLL = = 0.04 in.
(L/d)LL = 52.00 / 0.04 = 1435
 ΔLL = 0.04 in = L/1435 < L/360   ➜  OK
ΔTL = = 0.06 in.
(L/d)TL = 52.00 / 0.06 = 944
 ΔTL = 0.06 in = L/944 < L/240   ➜  OK
fc⊥ = = 151.6 psi
 fc⊥ = 151.6 psi < Fc⊥x' = 565.00 psi  (CSI = 0.27)   ➜  OK
Beam Design 2026A88
3/27/2026 6
