Size: 4 x 12
Design Span (L): 6.00 ft.
Clear Span: 5.75 ft.
Total Span: 6.25 ft.
Live Load: 40 plf
Dead Load: 15 plf
Selfweight: 56.1 lbs
Dist. Selfweight: 9.35 plf
Total Weight: 58.5 lbs
CL Beam Stability Factor 0.988 - - - - -
CF Size Factor 1.1 1 - 1 - -
Beam Design 2026A81
3/19/2026 1
Beam Design 2026A81
3/19/2026 2
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (72.00 + 3)] x (12 in./ft.)3 = 1.71 ft3
Volumespan = N[A x L] = 1 x [39.38 x 72.00] x (12 in./ft.)3 = 1.64 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.71 = 58.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.64 = 56.1 lbs
40 plf
15 plf
ws = 9.35 plf
5.75 ft.
6.25 ft.
201.10 lbs
201.10 lbs
Beam Design 2026A81
3/19/2026 3
lu = Unbraced Length = 6 ft.
lu/d = = 6.40
le = 2.06lu = 2.06(72.0) = 148.32 in. = 12.36 ft.  (NDS Table 3.3.3)
Rb = = 11.67
 Rb = 11.67 < 50   ➜  OK
Beam Design 2026A81
3/19/2026 4
FbE = = 5109.67 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.00)(1)(1)(1.1)(1)(1) = 990.00 psi
CL =   = 0.988
Fbx' = (900)(1.00)(1)(1)(0.988)(1.1)(1)(1) = 978.4 psi
fb = = 47.1 psi
 fb = 47.1 psi < Fbx' = 978.4 psi  (CSI = 0.05)   ➜  OK
fv* = = 5.06 psi
 fv* = 5.06 psi < Fvx' = 180.00 psi  (CSI = 0.03)   ➜  OK
fv = = 7.35 psi
 fv = 7.35 psi < Fvx' = 180.00 psi  (CSI = 0.04)   ➜  OK
Beam Design 2026A81
3/19/2026 5
ΔLL = = 0.00 in.
(L/d)LL = 72.00 / 0.00 = 41016
 ΔLL = 0.00 in = L/41016 < L/360   ➜  OK
ΔTL = = 0.00 in.
(L/d)TL = 72.00 / 0.00 = 25494
 ΔTL = 0.00 in = L/25494 < L/240   ➜  OK
fc⊥ = = 19.2 psi
 fc⊥ = 19.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.03)   ➜  OK
Beam Design 2026A81
3/19/2026 6
