Grade: SP No.1
Design Span (L): 5.75 ft.
Clear Span: 5.50 ft.
Total Span: 6.00 ft.
Live Load: 110 plf
Dead Load: 10 plf
Selfweight: 41.4 lbs
Dist. Selfweight: 7.19 plf
Total Weight: 43.2 lbs
Beam Design 2026A78
3/19/2026 1
Beam Design 2026A78
3/19/2026 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (69.00 + 3)] x (12 in./ft.)3 = 1.16 ft3
Volumespan = N[A x L] = 2 x [13.88 x 69.00] x (12 in./ft.)3 = 1.11 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.16 = 43.2 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.11 = 41.4 lbs
110 plf
10 plf
ws = 7.19 plf
5.75 ft.
5.50 ft.
381.58 lbs
381.58 lbs
Beam Design 2026A78
3/19/2026 3
Fbx' = (1050)(1.00)(1)(1)(1)(1)(1)(1) = 1050.0 psi
fb = = 147.4 psi
 fb = 147.4 psi < Fbx' = 1050.0 psi  (CSI = 0.14)   ➜  OK
Beam Design 2026A78
3/19/2026 4
fv* = = 14.47 psi
 fv* = 14.47 psi < Fvx' = 175.00 psi  (CSI = 0.08)   ➜  OK
fv = = 19.77 psi
 fv = 19.77 psi < Fvx' = 175.00 psi  (CSI = 0.11)   ➜  OK
Beam Design 2026A78
3/19/2026 5
ΔLL = = 0.01 in.
(L/d)LL = 69.00 / 0.01 = 8074
 ΔLL = 0.01 in = L/8074 < L/360   ➜  OK
ΔTL = = 0.01 in.
(L/d)TL = 69.00 / 0.01 = 6983
 ΔTL = 0.01 in = L/6983 < L/240   ➜  OK
fc⊥ = = 42.4 psi
 fc⊥ = 42.4 psi < Fc⊥x' = 565.00 psi  (CSI = 0.08)   ➜  OK
Beam Design 2026A78
3/19/2026 6
