Grade: SPF No.2
Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Selfweight: 107.4 lbs
Dist. Selfweight: 6.82 plf
Total Weight: 109.1 lbs
Beam Design 2026A75
3/5/2026 1
Beam Design 2026A75
3/5/2026 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (189.00 + 3)] x (12 in./ft.)3 = 3.75 ft3
Volumespan = N[A x L] = 2 x [16.88 x 189.00] x (12 in./ft.)3 = 3.69 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 3.75 = 109.1 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 3.69 = 107.4 lbs
ws = 6.82 plf
15.75 ft.
15.50 ft.
1454.56 lbs
1454.56 lbs
Beam Design 2026A75
3/5/2026 3
lu/d = = 2.13
Rb = = 7.86
 Rb = 7.86 < 50   ➜  OK
Beam Design 2026A75
3/5/2026 4
FbE = = 9902.91 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (875)(1.00)(1)(1)(1)(1)(1) = 875.00 psi
CL =   = 0.995
Fbx' = (875)(1.00)(1)(1)(0.995)(1)(1)(1) = 870.8 psi
fb = = 1069.1 psi
 fb = 1069.1 psi > Fbx' = 870.8 psi  (CSI = 1.23)   ➜  NG
fv* = = 56.06 psi
 fv* = 56.06 psi < Fvx' = 135.00 psi  (CSI = 0.42)   ➜  OK
fv = = 63.64 psi
 fv = 63.64 psi < Fvx' = 135.00 psi  (CSI = 0.47)   ➜  OK
Beam Design 2026A75
3/5/2026 5
ΔLL = = 0.28 in.
(L/d)LL = 189.00 / 0.28 = 680
 ΔLL = 0.28 in = L/680 < L/360   ➜  OK
ΔTL = = 0.51 in.
(L/d)TL = 189.00 / 0.51 = 374
 ΔTL = 0.51 in = L/374 < L/240   ➜  OK
fc⊥ = = 161.6 psi
 fc⊥ = 161.6 psi < Fc⊥x' = 425.00 psi  (CSI = 0.38)   ➜  OK
Beam Design 2026A75
3/5/2026 6
