Size: 6.75 x 13.5
Design Span (L): 17.46 ft.
Clear Span: 17.00 ft.
Total Span: 17.92 ft.
Bearing (lb): 5.5 in.
Live Load: 790 plf
Dead Load: 250 plf
Selfweight: 373.0 lbs
Dist. Selfweight: 21.36 plf
Total Weight: 382.8 lbs
CL Beam Stability Factor 0.979 - - - - -
CV Volume Factor 0.979b - - - - -
Beam Design 2026A7
1/6/2026 1
b = 6.750 in.
d = 13.500 in.
A = 6.750 x 13.500 = 91.13 in.2
Sx = (6.750)(13.500)2/6 = 205.03 in.3
Sy = (6.750)2(13.500)/6 = 102.52 in.3
Ix = (6.750)(13.500)3/12 = 1383.96 in.4
Iy = (6.750)3(13.500)/12 = 345.99 in.4
Beam Design 2026A7
1/6/2026 2
Volumetotal = N[A x (L + lb)] = 1 x [91.13 x (209.50 + 5.5)] x (12 in./ft.)3 = 11.34 ft3
Volumespan = N[A x L] = 1 x [91.13 x 209.50] x (12 in./ft.)3 = 11.05 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 11.34 = 382.8 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 11.05 = 373.0 lbs
Distributed Self Weight (ws) = = 21.36 plf
790 plf
250 plf
  ws = 21.36 plf
17.46 ft.
17.00 ft.
17.92 ft.
9507.88 lbs
9507.88 lbs
Beam Design 2026A7
1/6/2026 3
lu = Unbraced Length = 17.458 ft.
lu/d = = 15.52
le = 1.63lu + 3d = 1.63(209.5) + 3(13.5) = 381.98 in. = 31.83 ft.  (NDS Table 3.3.3)
Rb = = 10.64
 Rb = 10.64 < 50   ➜  OK
Beam Design 2026A7
1/6/2026 4
FbE = = 9012.29 psi
CL =   = 0.979
CV = = 0.979
CL = 0.979 < CV = 0.979
Fbx' = (2400)(1.15)(1)(1)(0.979) = 2702.1 psi
fb = = 2366.6 psi
 fb = 2366.6 psi < Fbx' = 2702.1 psi  (CSI = 0.88)   ➜  OK
fv* = = 132.85 psi
Beam Design 2026A7
1/6/2026 5
 fv* = 132.85 psi < Fvx' = 304.75 psi  (CSI = 0.44)   ➜  OK
fv = = 152.50 psi
 fv = 152.50 psi < Fvx' = 304.75 psi  (CSI = 0.50)   ➜  OK
ΔLL = = 0.66 in.
(L/d)LL = 209.50 / 0.66 = 316
 ΔLL = 0.66 in = L/316 < L/240   ➜  OK
ΔTL = = 0.89 in.
(L/d)TL = 209.50 / 0.89 = 235
 ΔTL = 0.89 in = L/235 < L/180   ➜  OK
Beam Design 2026A7
1/6/2026 6
Ab = b x lb = 6.75 x 5.5 = 37.13 in2
fc⊥ = = 256.1 psi
 fc⊥ = 256.1 psi < Fc⊥x' = 650.00 psi  (CSI = 0.39)   ➜  OK
Beam Design 2026A7
1/6/2026 7
