Size: 5.5 x 16.5
Design Span (L): 28.25 ft.
Clear Span: 28.00 ft.
Total Span: 28.50 ft.
Live Load: 240 plf
Dead Load: 60 plf
Selfweight: 601.1 lbs
Dist. Selfweight: 21.28 plf
Total Weight: 606.4 lbs
CV Volume Factor 0.934b - - - - -
Beam Design 110 Whitman
1/29/2026 1
d = 16.500 in.
1/29/2026 2
Volumetotal = N[A x (L + lb)] = 1 x [90.75 x (339.00 + 3)] x (12 in./ft.)3 = 17.96 ft3
Volumespan = N[A x L] = 1 x [90.75 x 339.00] x (12 in./ft.)3 = 17.80 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 17.96 = 606.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 17.80 = 601.1 lbs
240 plf
60 plf
  ws = 21.28 plf
28.25 ft.
28.00 ft.
28.50 ft.
4578.19 lbs
4578.19 lbs
1/29/2026 3
CV = = 0.934
CV = 0.934 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.934) = 2577.1 psi
fb = = 1541.1 psi
 fb = 1541.1 psi < Fbx' = 2577.1 psi  (CSI = 0.60)   ➜  OK
1/29/2026 4
fv* = = 67.71 psi
 fv* = 67.71 psi < Fvx' = 304.75 psi  (CSI = 0.22)   ➜  OK
fv = = 75.01 psi
 fv = 75.01 psi < Fvx' = 304.75 psi  (CSI = 0.25)   ➜  OK
1/29/2026 5
ΔLL = = 0.93 in.
(L/d)LL = 339.00 / 0.93 = 365
 ΔLL = 0.93 in = L/365 < L/360   ➜  OK
ΔTL = = 1.24 in.
(L/d)TL = 339.00 / 1.24 = 273
 ΔTL = 1.24 in = L/273 < L/240   ➜  OK
fc⊥ = = 277.5 psi
 fc⊥ = 277.5 psi < Fc⊥x' = 650.00 psi  (CSI = 0.43)   ➜  OK
1/29/2026 6
