Beam Design - BSMT CENTER BEAM
Size: 5.5 x 7.5
Design Span (L): 11.00 ft.
Clear Span: 10.75 ft.
Total Span: 11.25 ft.
Live Load: 408 plf
Dead Load: 114 plf
Selfweight: 106.4 lbs
Dist. Selfweight: 9.67 plf
Total Weight: 108.8 lbs
Beam Design MICHAEL LEWALLEN 319 NE CEDAR ST. CAMAS 2512
1/28/2026 1
d = 7.500 in.
A = 5.500 x 7.500 = 41.25 in.2
Sx = (5.500)(7.500)2/6 = 51.56 in.3
Sy = (5.500)2(7.500)/6 = 37.81 in.3
Ix = (5.500)(7.500)3/12 = 193.36 in.4
Iy = (5.500)3(7.500)/12 = 103.98 in.4
1/28/2026 2
Volumetotal = N[A x (L + lb)] = 1 x [41.25 x (132.00 + 3)] x (12 in./ft.)3 = 3.22 ft3
Volumespan = N[A x L] = 1 x [41.25 x 132.00] x (12 in./ft.)3 = 3.15 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.22 = 108.8 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.15 = 106.4 lbs
Distributed Self Weight (ws) = = 9.67 plf
408 plf
114 plf
  ws = 9.67 plf
11.00 ft.
10.75 ft.
11.25 ft.
2990.65 lbs
2990.65 lbs
1/28/2026 3
fb = = 1871.5 psi
 fb = 1871.5 psi < Fbx' = 2760.0 psi  (CSI = 0.68)   ➜  OK
1/28/2026 4
fv* = = 94.25 psi
 fv* = 94.25 psi < Fvx' = 304.75 psi  (CSI = 0.31)   ➜  OK
fv = = 106.33 psi
 fv = 106.33 psi < Fvx' = 304.75 psi  (CSI = 0.35)   ➜  OK
1/28/2026 5
ΔLL = = 0.39 in.
(L/d)LL = 132.00 / 0.39 = 342
 ΔLL = 0.39 in = L/342 > L/360   ➜  NG
ΔTL = = 0.50 in.
(L/d)TL = 132.00 / 0.50 = 262
 ΔTL = 0.50 in = L/262 < L/240   ➜  OK
fc⊥ = = 181.3 psi
 fc⊥ = 181.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.28)   ➜  OK
1/28/2026 6
