Beam Design - aerial support
Size: 2 x 14
Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Live Load: 5000 lbs
Dead Load: 10 lbs
Selfweight: 223.1 lbs
Dist. Selfweight: 14.16 plf
Total Weight: 226.6 lbs
CF Size Factor 0.9 0.9 - 0.9 - -
Beam Design 2025A98
4/16/2025 1
d = 13.250 in.
A = 1.500 x 13.250 = 19.88 in.2
Sx = (1.500)(13.250)2/6 = 43.89 in.3
Sy = (1.500)2(13.250)/6 = 4.97 in.3
Ix = (1.500)(13.250)3/12 = 290.78 in.4
Iy = (1.500)3(13.250)/12 = 3.73 in.4
Beam Design 2025A98
4/16/2025 2
Volumetotal = N[A x (L + lb)] = 3 x [19.88 x (189.00 + 3)] x (12 in./ft.)3 = 6.63 ft3
Volumespan = N[A x L] = 3 x [19.88 x 189.00] x (12 in./ft.)3 = 6.52 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 6.63 = 226.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 6.52 = 223.1 lbs
Distributed Self Weight (ws) = = 14.16 plf
5000 lbs
10 lbs
ws = 14.16 plf
15.75 ft.
15.50 ft.
2618.30 lbs
2618.30 lbs
Beam Design 2025A98
4/16/2025 3
Fbx' = (900)(1.00)(1)(1)(1)(0.9)(1)(1) = 810.0 psi
fb = = 1837.8 psi
 fb = 1837.8 psi > Fbx' = 810.0 psi  (CSI = 2.27)   ➜  NG
Beam Design 2025A98
4/16/2025 4
fv* = = 65.43 psi
 fv* = 65.43 psi < Fvx' = 180.00 psi  (CSI = 0.36)   ➜  OK
fv = = 65.82 psi
 fv = 65.82 psi < Fvx' = 180.00 psi  (CSI = 0.37)   ➜  OK
Beam Design 2025A98
4/16/2025 5
ΔLL =   =   = 0.50 in.
(L/d)LL = 189.00 / 0.50 = 375
 ΔLL = 0.50 in = L/375 < L/360   ➜  OK
ΔTL =   =   = 0.52 in.
(L/d)TL = 189.00 / 0.52 = 364
 ΔTL = 0.52 in = L/364 < L/240   ➜  OK
fc⊥ = = 193.9 psi
 fc⊥ = 193.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.31)   ➜  OK
Beam Design 2025A98
4/16/2025 6
