Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Live Load: 314 plf
Dead Load: 135 plf
Selfweight: 78.2 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 80.2 lbs
Beam Design Thomas 2025A94
4/15/2025 1
4/15/2025 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (117.00 + 3)] x (12 in./ft.)3 = 2.34 ft3
Volumespan = N[A x L] = 2 x [16.88 x 117.00] x (12 in./ft.)3 = 2.29 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.34 = 80.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.29 = 78.2 lbs
314 plf
135 plf
ws = 8.02 plf
9.75 ft.
9.50 ft.
10.00 ft.
2285.08 lbs
2285.08 lbs
4/15/2025 3
fb = = 1029.8 psi
 fb = 1029.8 psi < Fbx' = 1035.0 psi  (CSI = 0.99)   ➜  OK
4/15/2025 4
fv* = = 79.98 psi
 fv* = 79.98 psi < Fvx' = 207.00 psi  (CSI = 0.39)   ➜  OK
fv = = 99.02 psi
 fv = 99.02 psi < Fvx' = 207.00 psi  (CSI = 0.48)   ➜  OK
4/15/2025 5
ΔLL = = 0.11 in.
(L/d)LL = 117.00 / 0.11 = 1044
 ΔLL = 0.11 in = L/1044 < L/180   ➜  OK
ΔTL = = 0.16 in.
(L/d)TL = 117.00 / 0.16 = 717
 ΔTL = 0.16 in = L/717 < L/120   ➜  OK
fc⊥ = = 253.9 psi
 fc⊥ = 253.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.41)   ➜  OK
4/15/2025 6
