Beam Design - AZ Beam Check
Size: 5.125 x 21
Design Span (L): 23.75 ft.
Clear Span: 23.50 ft.
Total Span: 24.00 ft.
Live Load: 20 plf
Dead Load: 24 plf
Selfweight: 599.3 lbs
Dist. Selfweight: 25.23 plf
Total Weight: 605.6 lbs
Load Duration: 1.25
Notes: For Calcs
CV Volume Factor 0.934b - - - - -
Beam Design Alex Ravski 67 Arborside 25-013
4/1/2025 1
b = 5.125 in.
d = 21.000 in.
A = 5.125 x 21.000 = 107.63 in.2
Sx = (5.125)(21.000)2/6 = 376.69 in.3
Sy = (5.125)2(21.000)/6 = 91.93 in.3
Ix = (5.125)(21.000)3/12 = 3955.22 in.4
Iy = (5.125)3(21.000)/12 = 235.57 in.4
4/1/2025 2
Volumetotal = N[A x (L + lb)] = 1 x [107.63 x (285.00 + 3)] x (12 in./ft.)3 = 17.94 ft3
Volumespan = N[A x L] = 1 x [107.63 x 285.00] x (12 in./ft.)3 = 17.75 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 17.94 = 605.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 17.75 = 599.3 lbs
Distributed Self Weight (ws) = = 25.23 plf
20 plf
24 plf
  ws = 25.23 plf
23.75 ft.
23.50 ft.
24.00 ft.
830.80 lbs
830.80 lbs
4/1/2025 3
CV = = 0.934
CV = 0.934 < CL = 1
Fbx' = (2400)(1.25)(1)(1)(0.934) = 2802.0 psi
fb = = 155.5 psi
 fb = 155.5 psi < Fbx' = 2802.0 psi  (CSI = 0.06)   ➜  OK
4/1/2025 4
fv* = = 9.77 psi
 fv* = 9.77 psi < Fvx' = 331.25 psi  (CSI = 0.03)   ➜  OK
fv = = 11.46 psi
 fv = 11.46 psi < Fvx' = 331.25 psi  (CSI = 0.03)   ➜  OK
4/1/2025 5
ΔLL = = 0.02 in.
(L/d)LL = 285.00 / 0.02 = 14172
 ΔLL = 0.02 in = L/14172 < L/360   ➜  OK
ΔTL = = 0.07 in.
(L/d)TL = 285.00 / 0.07 = 4094
 ΔTL = 0.07 in = L/4094 < L/240   ➜  OK
fc⊥ = = 54.0 psi
 fc⊥ = 54.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.08)   ➜  OK
4/1/2025 6
