Design Span (L): 10.25 ft.
Clear Span: 10.00 ft.
Total Span: 10.50 ft.
Live Load: 320 plf
Dead Load: 95 plf
Selfweight: 82.2 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 84.2 lbs
Beam Design 2025A89
3/31/2025 1
Beam Design 2025A89
3/31/2025 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (123.00 + 3)] x (12 in./ft.)3 = 2.46 ft3
Volumespan = N[A x L] = 2 x [16.88 x 123.00] x (12 in./ft.)3 = 2.40 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.46 = 84.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.40 = 82.2 lbs
320 plf
95 plf
ws = 8.02 plf
10.25 ft.
10.00 ft.
10.50 ft.
2220.84 lbs
2220.84 lbs
Beam Design 2025A89
3/31/2025 3
fb = = 1053.5 psi
 fb = 1053.5 psi > Fbx' = 1035.0 psi  (CSI = 1.02)   ➜  NG
Beam Design 2025A89
3/31/2025 4
fv* = = 78.73 psi
 fv* = 78.73 psi < Fvx' = 207.00 psi  (CSI = 0.38)   ➜  OK
fv = = 96.35 psi
 fv = 96.35 psi < Fvx' = 207.00 psi  (CSI = 0.47)   ➜  OK
Beam Design 2025A89
3/31/2025 5
ΔLL = = 0.14 in.
(L/d)LL = 123.00 / 0.14 = 881
 ΔLL = 0.14 in = L/881 < L/180   ➜  OK
ΔTL = = 0.18 in.
(L/d)TL = 123.00 / 0.18 = 667
 ΔTL = 0.18 in = L/667 < L/120   ➜  OK
fc⊥ = = 246.8 psi
 fc⊥ = 246.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.39)   ➜  OK
Beam Design 2025A89
3/31/2025 6
