Beam Design - Header 1
Design Span (L): 10.25 ft.
Clear Span: 10.00 ft.
Total Span: 10.50 ft.
Live Load: 350 plf
Dead Load: 220 plf
Selfweight: 82.2 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 84.2 lbs
Notes: Header made with 2 2x12 lumber
Beam Design C. Beck Highland Road, Bend Header 1
3/30/2025 1
3/30/2025 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (123.00 + 3)] x (12 in./ft.)3 = 2.46 ft3
Volumespan = N[A x L] = 2 x [16.88 x 123.00] x (12 in./ft.)3 = 2.40 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.46 = 84.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.40 = 82.2 lbs
350 plf
220 plf
ws = 8.02 plf
10.25 ft.
10.00 ft.
10.50 ft.
3034.59 lbs
3034.59 lbs
3/30/2025 3
fb = = 1439.5 psi
 fb = 1439.5 psi > Fbx' = 1035.0 psi  (CSI = 1.39)   ➜  NG
3/30/2025 4
fv* = = 107.58 psi
 fv* = 107.58 psi < Fvx' = 207.00 psi  (CSI = 0.52)   ➜  OK
fv = = 131.66 psi
 fv = 131.66 psi < Fvx' = 207.00 psi  (CSI = 0.64)   ➜  OK
3/30/2025 5
ΔLL = = 0.15 in.
(L/d)LL = 123.00 / 0.15 = 806
 ΔLL = 0.15 in = L/806 < L/360   ➜  OK
ΔTL = = 0.25 in.
(L/d)TL = 123.00 / 0.25 = 488
 ΔTL = 0.25 in = L/488 < L/240   ➜  OK
fc⊥ = = 337.2 psi
 fc⊥ = 337.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.54)   ➜  OK
3/30/2025 6
