Beam Design - Header 1
Design Span (L): 10.25 ft.
Clear Span: 10.00 ft.
Total Span: 10.50 ft.
Live Load: 350 plf
Dead Load: 220 plf
Selfweight: 67.6 lbs
Dist. Selfweight: 6.59 plf
Total Weight: 69.2 lbs
Notes: Header with 2 2x10
Beam Design Captain Deadeye Header 1
3/30/2025 1
3/30/2025 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (123.00 + 3)] x (12 in./ft.)3 = 2.02 ft3
Volumespan = N[A x L] = 2 x [13.88 x 123.00] x (12 in./ft.)3 = 1.98 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.02 = 69.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.98 = 67.6 lbs
350 plf
220 plf
ws = 6.59 plf
10.25 ft.
10.00 ft.
10.50 ft.
3027.10 lbs
3027.10 lbs
3/30/2025 3
fb = = 2124.0 psi
 fb = 2124.0 psi > Fbx' = 1138.5 psi  (CSI = 1.87)   ➜  NG
3/30/2025 4
fv* = = 135.71 psi
 fv* = 135.71 psi < Fvx' = 207.00 psi  (CSI = 0.66)   ➜  OK
fv = = 159.73 psi
 fv = 159.73 psi < Fvx' = 207.00 psi  (CSI = 0.77)   ➜  OK
3/30/2025 5
ΔLL = = 0.27 in.
(L/d)LL = 123.00 / 0.27 = 448
 ΔLL = 0.27 in = L/448 < L/180   ➜  OK
ΔTL = = 0.45 in.
(L/d)TL = 123.00 / 0.45 = 272
 ΔTL = 0.45 in = L/272 < L/120   ➜  OK
fc⊥ = = 336.3 psi
 fc⊥ = 336.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.54)   ➜  OK
3/30/2025 6
