Beam Design - RIDGE BEAM SUPPORT
Size: 5.125 x 10.5
Design Span (L): 12.20 ft.
Clear Span: 11.74 ft.
Total Span: 12.66 ft.
Bearing (lb): 5.5 in.
Live Load: 0 lbs
Dead Load: 6391 lbs
Selfweight: 153.9 lbs
Dist. Selfweight: 12.62 plf
Total Weight: 159.7 lbs
Beam Design ALEX WW SPGS
3/26/2025 1
b = 5.125 in.
d = 10.500 in.
A = 5.125 x 10.500 = 53.81 in.2
Sx = (5.125)(10.500)2/6 = 94.17 in.3
Sy = (5.125)2(10.500)/6 = 45.96 in.3
Ix = (5.125)(10.500)3/12 = 494.40 in.4
Iy = (5.125)3(10.500)/12 = 117.78 in.4
3/26/2025 2
Volumetotal = N[A x (L + lb)] = 1 x [53.81 x (146.42 + 5.5)] x (12 in./ft.)3 = 4.73 ft3
Volumespan = N[A x L] = 1 x [53.81 x 146.42] x (12 in./ft.)3 = 4.56 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 4.73 = 159.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 4.56 = 153.9 lbs
Distributed Self Weight (ws) = = 12.62 plf
0 lbs
6391 lbs
  ws = 12.62 plf
12.20 ft.
11.74 ft.
12.66 ft.
3275.36 lbs
3275.36 lbs
3/26/2025 3
Fbx' = (2400)(0.9)(1)(1)(1.0) = 2160.0 psi
fb = = 2514.2 psi
 fb = 2514.2 psi > Fbx' = 2160.0 psi  (CSI = 1.16)   ➜  NG
3/26/2025 4
Fvx' = (265)(0.9)(1)(1) = 238.50 psi
fv* = = 90.91 psi
 fv* = 90.91 psi < Fvx' = 238.50 psi  (CSI = 0.38)   ➜  OK
fv = = 91.22 psi
 fv = 91.22 psi < Fvx' = 238.50 psi  (CSI = 0.38)   ➜  OK
3/26/2025 5
ΔLL =   =   = 0.00 in.
(L/d)LL = 146.42 / 0.00 = ∞
ΔTL =   =   = 0.48 in.
(L/d)TL = 146.42 / 0.48 = 307
 ΔTL = 0.48 in = L/307 < L/240   ➜  OK
fc⊥ = = 116.2 psi
 fc⊥ = 116.2 psi < Fc⊥x' = 650.00 psi  (CSI = 0.18)   ➜  OK
3/26/2025 6
