Size: 3.5 x 10.5
Design Span (L): 23.58 ft.
Clear Span: 23.17 ft.
Total Span: 24.00 ft.
Bearing (lb): 5 in.
Selfweight: 609.6 lbs
Dist. Selfweight: 25.85 plf
Total Weight: 620.4 lbs
Beam Design 2025A79
3/9/2025 1
d = 10.500 in.
A = 3.500 x 10.500 = 36.75 in.2
Sx = (3.500)(10.500)2/6 = 64.31 in.3
Sy = (3.500)2(10.500)/6 = 21.44 in.3
Ix = (3.500)(10.500)3/12 = 337.64 in.4
Iy = (3.500)3(10.500)/12 = 37.52 in.4
Beam Design 2025A79
3/9/2025 2
Volumetotal = N[A x (L + lb)] = 3 x [36.75 x (283.00 + 5)] x (12 in./ft.)3 = 18.37 ft3
Volumespan = N[A x L] = 3 x [36.75 x 283.00] x (12 in./ft.)3 = 18.06 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 18.37 = 620.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 18.06 = 609.6 lbs
Distributed Self Weight (ws) = = 25.85 plf
  ws = 25.85 plf
23.58 ft.
23.17 ft.
24.00 ft.
2410.15 lbs
2410.15 lbs
Beam Design 2025A79
3/9/2025 3
fb = = 868.4 psi
 fb = 868.4 psi < Fbx' = 2760.0 psi  (CSI = 0.31)   ➜  OK
Beam Design 2025A79
3/9/2025 4
fv* = = 29.83 psi
 fv* = 29.83 psi < Fvx' = 304.75 psi  (CSI = 0.10)   ➜  OK
fv = = 32.22 psi
 fv = 32.22 psi < Fvx' = 304.75 psi  (CSI = 0.11)   ➜  OK
Beam Design 2025A79
3/9/2025 5
ΔLL = = 0.38 in.
(L/d)LL = 283.00 / 0.38 = 741
 ΔLL = 0.38 in = L/741 < L/180   ➜  OK
ΔTL = = 0.77 in.
(L/d)TL = 283.00 / 0.77 = 369
 ΔTL = 0.77 in = L/369 < L/120   ➜  OK
Ab = b x lb = 3.5 x 5 = 17.50 in2
fc⊥ = = 45.9 psi
 fc⊥ = 45.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.07)   ➜  OK
Beam Design 2025A79
3/9/2025 6
