Size: 2.5 x 6
Design Span (L): 24.25 ft.
Clear Span: 24.00 ft.
Total Span: 24.50 ft.
Selfweight: 85.3 lbs
Dist. Selfweight: 3.52 plf
Total Weight: 86.2 lbs
Beam Design 2025A76
3/8/2025 1
b = 2.500 in.
d = 6.000 in.
A = 2.500 x 6.000 = 15.00 in.2
Sx = (2.500)(6.000)2/6 = 15.00 in.3
Sy = (2.500)2(6.000)/6 = 6.25 in.3
Ix = (2.500)(6.000)3/12 = 45.00 in.4
Iy = (2.500)3(6.000)/12 = 7.81 in.4
Beam Design 2025A76
3/8/2025 2
Volumetotal = N[A x (L + lb)] = 1 x [15.00 x (291.00 + 3)] x (12 in./ft.)3 = 2.55 ft3
Volumespan = N[A x L] = 1 x [15.00 x 291.00] x (12 in./ft.)3 = 2.53 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 2.55 = 86.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 2.53 = 85.3 lbs
  ws = 3.52 plf
24.25 ft.
24.00 ft.
24.50 ft.
2186.83 lbs
2186.83 lbs
Beam Design 2025A76
3/8/2025 3
fb = = 10497.9 psi
 fb = 10497.9 psi > Fbx' = 2760.0 psi  (CSI = 3.80)   ➜  NG
Beam Design 2025A76
3/8/2025 4
fv* = = 207.53 psi
 fv* = 207.53 psi < Fvx' = 304.75 psi  (CSI = 0.68)   ➜  OK
fv = = 216.45 psi
 fv = 216.45 psi < Fvx' = 304.75 psi  (CSI = 0.71)   ➜  OK
Beam Design 2025A76
3/8/2025 5
ΔLL = = 9.61 in.
(L/d)LL = 291.00 / 9.61 = 30
 ΔLL = 9.61 in = L/30 > L/360   ➜  NG
ΔTL = = 17.15 in.
(L/d)TL = 291.00 / 17.15 = 17
 ΔTL = 17.15 in = L/17 > L/240   ➜  NG
fc⊥ = = 291.6 psi
 fc⊥ = 291.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.45)   ➜  OK
Beam Design 2025A76
3/8/2025 6
