Beam Design - Alberts Window
Design Span (L): 5.25 ft.
Clear Span: 5.00 ft.
Total Span: 5.50 ft.
Live Load: 0 plf
Dead Load: 100 plf
Selfweight: 13.6 lbs
Dist. Selfweight: 2.58 plf
Total Weight: 14.2 lbs
Beam Design 001
3/8/2025 1
Beam Design 001
3/8/2025 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (63.00 + 3)] x (12 in./ft.)3 = 0.42 ft3
Volumespan = N[A x L] = 1 x [10.88 x 63.00] x (12 in./ft.)3 = 0.40 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.42 = 14.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.40 = 13.6 lbs
0 plf
ws = 2.58 plf
5.25 ft.
5.00 ft.
5.50 ft.
282.10 lbs
282.10 lbs
Beam Design 001
3/8/2025 3
Fbx' = (900)(0.9)(1)(1)(1)(1.2)(1)(1) = 972.0 psi
fb = = 322.8 psi
 fb = 322.8 psi < Fbx' = 972.0 psi  (CSI = 0.33)   ➜  OK
Beam Design 001
3/8/2025 4
fv* = = 28.59 psi
 fv* = 28.59 psi < Fvx' = 162.00 psi  (CSI = 0.18)   ➜  OK
fv = = 37.14 psi
 fv = 37.14 psi < Fvx' = 162.00 psi  (CSI = 0.23)   ➜  OK
Beam Design 001
3/8/2025 5
ΔLL = = 0.00 in.
(L/d)LL = 63.00 / 0.00 = ∞
ΔTL = = 0.02 in.
(L/d)TL = 63.00 / 0.02 = 2738
 ΔTL = 0.02 in = L/2738 < L/240   ➜  OK
fc⊥ = = 62.7 psi
 fc⊥ = 62.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.10)   ➜  OK
Beam Design 001
3/8/2025 6
