Beam Design - Girt Design - Effingham Duplex
Grade: SP DSS
Design Span (L): 7.00 ft.
Clear Span: 6.75 ft.
Total Span: 7.25 ft.
Live Load: 300 plf
Dead Load: 25 plf
Selfweight: 39.5 lbs
Dist. Selfweight: 5.64 plf
Total Weight: 40.9 lbs
Beam Design Corn Bros. Properties, Inc. 1096 Co Rd 1200 N Toledo, IL 62468 2025A7
1/9/2025 1
SP DSS 2200 1550 175 660 1850 1900000 690000 0.55
1/9/2025 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (84.00 + 3)] x (12 in./ft.)3 = 1.10 ft3
Volumespan = N[A x L] = 2 x [10.88 x 84.00] x (12 in./ft.)3 = 1.06 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.10 = 40.9 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.06 = 39.5 lbs
300 plf
25 plf
ws = 5.64 plf
7.00 ft.
6.75 ft.
7.25 ft.
1198.56 lbs
1198.56 lbs
1/9/2025 3
Fbx' = (2200)(1.15)(1)(1)(1)(1)(1)(1) = 2530.0 psi
fb = = 924.7 psi
 fb = 924.7 psi < Fbx' = 2530.0 psi  (CSI = 0.37)   ➜  OK
1/9/2025 4
fv* = = 66.03 psi
 fv* = 66.03 psi < Fvx' = 201.25 psi  (CSI = 0.33)   ➜  OK
fv = = 79.81 psi
 fv = 79.81 psi < Fvx' = 201.25 psi  (CSI = 0.40)   ➜  OK
1/9/2025 5
ΔLL = = 0.09 in.
(L/d)LL = 84.00 / 0.09 = 938
 ΔLL = 0.09 in = L/938 < L/360   ➜  OK
ΔTL = = 0.10 in.
(L/d)TL = 84.00 / 0.10 = 851
 ΔTL = 0.10 in = L/851 < L/240   ➜  OK
fc⊥ = = 133.2 psi
 fc⊥ = 133.2 psi < Fc⊥x' = 660.00 psi  (CSI = 0.20)   ➜  OK
1/9/2025 6
