Beam Design - Alberts Patio Door
Live Load: 0 plf
Dead Load: 167 plf
Selfweight: 77.4 lbs
Dist. Selfweight: 6.59 plf
Total Weight: 79.1 lbs
Beam Design 001
3/8/2025 1
Beam Design 001
3/8/2025 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (141.00 + 3)] x (12 in./ft.)3 = 2.31 ft3
Volumespan = N[A x L] = 2 x [13.88 x 141.00] x (12 in./ft.)3 = 2.26 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.31 = 79.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.26 = 77.4 lbs
0 plf
167 plf
ws = 6.59 plf
1041.55 lbs
1041.55 lbs
Beam Design 001
3/8/2025 3
Fbx' = (900)(0.9)(1)(1)(1)(1.1)(1)(1) = 891.0 psi
fb = = 840.3 psi
 fb = 840.3 psi < Fbx' = 891.0 psi  (CSI = 0.94)   ➜  OK
Beam Design 001
3/8/2025 4
fv* = = 47.89 psi
 fv* = 47.89 psi < Fvx' = 162.00 psi  (CSI = 0.30)   ➜  OK
fv = = 55.13 psi
 fv = 55.13 psi < Fvx' = 162.00 psi  (CSI = 0.34)   ➜  OK
Beam Design 001
3/8/2025 5
ΔLL = = 0.00 in.
(L/d)LL = 141.00 / 0.00 = ∞
ΔTL = = 0.24 in.
(L/d)TL = 141.00 / 0.24 = 600
 ΔTL = 0.24 in = L/600 < L/240   ➜  OK
fc⊥ = = 115.7 psi
 fc⊥ = 115.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.19)   ➜  OK
Beam Design 001
3/8/2025 6
