Beam Design - Alberts
Design Span (L): 12.25 ft.
Clear Span: 12.00 ft.
Total Span: 12.50 ft.
Live Load: 0 plf
Dead Load: 167 plf
Selfweight: 98.2 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 100.2 lbs
Beam Design Steven Wohlscheid 11477 S Bauer Road, Eagle, MI 2025A67
3/8/2025 1
3/8/2025 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (147.00 + 3)] x (12 in./ft.)3 = 2.93 ft3
Volumespan = N[A x L] = 2 x [16.88 x 147.00] x (12 in./ft.)3 = 2.87 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.93 = 100.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.87 = 98.2 lbs
0 plf
167 plf
ws = 8.02 plf
12.25 ft.
12.50 ft.
1093.85 lbs
1093.85 lbs
3/8/2025 3
Fbx' = (900)(0.9)(1)(1)(1)(1)(1)(1) = 810.0 psi
fb = = 622.5 psi
 fb = 622.5 psi < Fbx' = 810.0 psi  (CSI = 0.77)   ➜  OK
3/8/2025 4
fv* = = 40.35 psi
 fv* = 40.35 psi < Fvx' = 162.00 psi  (CSI = 0.25)   ➜  OK
fv = = 47.64 psi
 fv = 47.64 psi < Fvx' = 162.00 psi  (CSI = 0.29)   ➜  OK
3/8/2025 5
ΔLL = = 0.00 in.
(L/d)LL = 147.00 / 0.00 = ∞
ΔTL = = 0.16 in.
(L/d)TL = 147.00 / 0.16 = 944
 ΔTL = 0.16 in = L/944 < L/240   ➜  OK
fc⊥ = = 121.5 psi
 fc⊥ = 121.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.19)   ➜  OK
3/8/2025 6
