Beam Design - Main Body Ridge BeaMS
Size: 3.5 x 12
Design Span (L): 14.00 ft.
Clear Span: 13.75 ft.
Total Span: 14.25 ft.
Selfweight: 137.9 lbs
Dist. Selfweight: 9.85 plf
Total Weight: 140.3 lbs
Beam Design Allen Burt 8061 Sportsman Club Rd NE Bainbridge Is 98110 WA 24-152 Nelson
3/3/2025 1
3/3/2025 2
Volumetotal = N[A x (L + lb)] = 1 x [42.00 x (168.00 + 3)] x (12 in./ft.)3 = 4.16 ft3
Volumespan = N[A x L] = 1 x [42.00 x 168.00] x (12 in./ft.)3 = 4.08 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 4.16 = 140.3 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 4.08 = 137.9 lbs
  ws = 9.85 plf
13.75 ft.
14.25 ft.
1317.03 lbs
1317.03 lbs
3/3/2025 3
fb = = 647.0 psi
 fb = 647.0 psi < Fbx' = 2760.0 psi  (CSI = 0.23)   ➜  OK
3/3/2025 4
fv* = = 39.61 psi
 fv* = 39.61 psi < Fvx' = 304.75 psi  (CSI = 0.13)   ➜  OK
fv = = 46.21 psi
 fv = 46.21 psi < Fvx' = 304.75 psi  (CSI = 0.15)   ➜  OK
3/3/2025 5
ΔLL = = 0.10 in.
(L/d)LL = 168.00 / 0.10 = 1763
 ΔLL = 0.10 in = L/1763 < L/240   ➜  OK
ΔTL = = 0.18 in.
(L/d)TL = 168.00 / 0.18 = 954
 ΔTL = 0.18 in = L/954 < L/180   ➜  OK
fc⊥ = = 125.4 psi
 fc⊥ = 125.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.19)   ➜  OK
3/3/2025 6
