Beam Design - Sherrad
Size: 5.5 x 13.5
Design Span (L): 27.75 ft.
Clear Span: 27.50 ft.
Total Span: 28.00 ft.
Dead Load: 0 plf
Selfweight: 483.1 lbs
Dist. Selfweight: 17.41 plf
Total Weight: 487.4 lbs
CV Volume Factor 0.954b - - - - -
Beam Design 22-246
2/28/2025 1
d = 13.500 in.
Beam Design 22-246
2/28/2025 2
Volumetotal = N[A x (L + lb)] = 1 x [74.25 x (333.00 + 3)] x (12 in./ft.)3 = 14.44 ft3
Volumespan = N[A x L] = 1 x [74.25 x 333.00] x (12 in./ft.)3 = 14.31 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 14.44 = 487.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 14.31 = 483.1 lbs
0 plf
  ws = 17.41 plf
27.75 ft.
27.50 ft.
28.00 ft.
1643.71 lbs
1643.71 lbs
Beam Design 22-246
2/28/2025 3
CV = = 0.954
CV = 0.954 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.954) = 2634.0 psi
fb = = 811.8 psi
 fb = 811.8 psi < Fbx' = 2634.0 psi  (CSI = 0.31)   ➜  OK
Beam Design 22-246
2/28/2025 4
fv* = = 30.24 psi
 fv* = 30.24 psi < Fvx' = 304.75 psi  (CSI = 0.10)   ➜  OK
fv = = 32.91 psi
 fv = 32.91 psi < Fvx' = 304.75 psi  (CSI = 0.11)   ➜  OK
Beam Design 22-246
2/28/2025 5
ΔLL = = 0.66 in.
(L/d)LL = 333.00 / 0.66 = 507
 ΔLL = 0.66 in = L/507 < L/360   ➜  OK
ΔTL = = 0.77 in.
(L/d)TL = 333.00 / 0.77 = 431
 ΔTL = 0.77 in = L/431 < L/240   ➜  OK
fc⊥ = = 99.6 psi
 fc⊥ = 99.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.15)   ➜  OK
Beam Design 22-246
2/28/2025 6
