Beam Design - 25 Market St, Chelsea, NY 12512
Grade: 24F-V3 1.8E SP/SP
Size: 3.5 x 12.375
Design Span (L): 16.25 ft.
Clear Span: 16.00 ft.
Total Span: 16.50 ft.
Selfweight: 180.3 lbs
Dist. Selfweight: 11.10 plf
Total Weight: 183.1 lbs
CL Beam Stability Factor 0.829 - - - - -
Beam Design Moin Awais 25 Market St, Chelsea, NY 12512 1
2/27/2025 1
d = 12.375 in.
A = 3.500 x 12.375 = 43.31 in.2
Sx = (3.500)(12.375)2/6 = 89.33 in.3
Sy = (3.500)2(12.375)/6 = 25.27 in.3
Ix = (3.500)(12.375)3/12 = 552.74 in.4
Iy = (3.500)3(12.375)/12 = 44.21 in.4
2/27/2025 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [43.31 x (195.00 + 3)] x (12 in./ft.)3 = 4.96 ft3
Volumespan = N[A x L] = 1 x [43.31 x 195.00] x (12 in./ft.)3 = 4.89 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 4.96 = 183.1 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 4.89 = 180.3 lbs
Distributed Self Weight (ws) = = 11.10 plf
  ws = 11.10 plf
16.25 ft.
16.50 ft.
1535.29 lbs
1535.29 lbs
2/27/2025 3
lu = Unbraced Length = 16.250 ft.
lu/d = = 15.76
le = 1.63lu + 3d = 1.63(195.0) + 3(12.375) = 354.97 in. = 29.58 ft.  (NDS Table 3.3.3)
Rb = = 18.94
 Rb = 18.94 < 50   ➜  OK
2/27/2025 4
FbE = = 2844.42 psi
CL =   = 0.829
CL = 0.829 < CV = 1.0
Fbx' = (2400)(1.15)(1)(1)(0.829) = 2288.7 psi
fb = = 825.1 psi
 fb = 825.1 psi < Fbx' = 2288.7 psi  (CSI = 0.36)   ➜  OK
fv* = = 45.72 psi
2/27/2025 5
 fv* = 45.72 psi < Fvx' = 345.00 psi  (CSI = 0.13)   ➜  OK
fv = = 52.36 psi
 fv = 52.36 psi < Fvx' = 345.00 psi  (CSI = 0.15)   ➜  OK
ΔLL = = 0.16 in.
(L/d)LL = 195.00 / 0.16 = 1237
 ΔLL = 0.16 in = L/1237 < L/360   ➜  OK
ΔTL = = 0.29 in.
(L/d)TL = 195.00 / 0.29 = 665
 ΔTL = 0.29 in = L/665 < L/240   ➜  OK
2/27/2025 6
fc⊥ = = 146.2 psi
 fc⊥ = 146.2 psi < Fc⊥x' = 740.00 psi  (CSI = 0.20)   ➜  OK
2/27/2025 7
