Size: 5.125 x 9
Design Span (L): 10.25 ft.
Clear Span: 10.00 ft.
Total Span: 10.50 ft.
Selfweight: 332.5 lbs
Dist. Selfweight: 32.44 plf
Total Weight: 340.6 lbs
Beam Design 2025A50
2/21/2025 1
b = 5.125 in.
d = 9.000 in.
A = 5.125 x 9.000 = 46.13 in.2
Sx = (5.125)(9.000)2/6 = 69.19 in.3
Sy = (5.125)2(9.000)/6 = 39.40 in.3
Ix = (5.125)(9.000)3/12 = 311.34 in.4
Iy = (5.125)3(9.000)/12 = 100.96 in.4
Beam Design 2025A50
2/21/2025 2
Volumetotal = N[A x (L + lb)] = 3 x [46.13 x (123.00 + 3)] x (12 in./ft.)3 = 10.09 ft3
Volumespan = N[A x L] = 3 x [46.13 x 123.00] x (12 in./ft.)3 = 9.85 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 10.09 = 340.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 9.85 = 332.5 lbs
Distributed Self Weight (ws) = = 32.44 plf
  ws = 32.44 plf
10.25 ft.
10.00 ft.
10.50 ft.
1089.07 lbs
1089.07 lbs
Beam Design 2025A50
2/21/2025 3
fb = = 157.5 psi
 fb = 157.5 psi < Fbx' = 2760.0 psi  (CSI = 0.06)   ➜  OK
Beam Design 2025A50
2/21/2025 4
fv* = = 9.84 psi
 fv* = 9.84 psi < Fvx' = 304.75 psi  (CSI = 0.03)   ➜  OK
fv = = 11.52 psi
 fv = 11.52 psi < Fvx' = 304.75 psi  (CSI = 0.04)   ➜  OK
Beam Design 2025A50
2/21/2025 5
ΔLL = = 0.01 in.
(L/d)LL = 123.00 / 0.01 = 8326
 ΔLL = 0.01 in = L/8326 < L/360   ➜  OK
ΔTL = = 0.03 in.
(L/d)TL = 123.00 / 0.03 = 4014
 ΔTL = 0.03 in = L/4014 < L/240   ➜  OK
fc⊥ = = 23.6 psi
 fc⊥ = 23.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.04)   ➜  OK
Beam Design 2025A50
2/21/2025 6
