Grade: SPF No.2
Design Span (L): 7.00 ft.
Clear Span: 6.75 ft.
Total Span: 7.25 ft.
Live Load: 300 plf
Dead Load: 25 plf
Selfweight: 30.8 lbs
Dist. Selfweight: 4.39 plf
Total Weight: 31.9 lbs
Beam Design 2025A5
1/9/2025 1
Beam Design 2025A5
1/9/2025 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (84.00 + 3)] x (12 in./ft.)3 = 1.10 ft3
Volumespan = N[A x L] = 2 x [10.88 x 84.00] x (12 in./ft.)3 = 1.06 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.10 = 31.9 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.06 = 30.8 lbs
300 plf
25 plf
ws = 4.39 plf
7.00 ft.
6.75 ft.
7.25 ft.
1194.06 lbs
1194.06 lbs
Beam Design 2025A5
1/9/2025 3
Fbx' = (875)(1.15)(1)(1)(1)(1.2)(1)(1) = 1207.5 psi
fb = = 921.2 psi
 fb = 921.2 psi < Fbx' = 1207.5 psi  (CSI = 0.76)   ➜  OK
Beam Design 2025A5
1/9/2025 4
fv* = = 65.78 psi
 fv* = 65.78 psi < Fvx' = 155.25 psi  (CSI = 0.42)   ➜  OK
fv = = 79.51 psi
 fv = 79.51 psi < Fvx' = 155.25 psi  (CSI = 0.51)   ➜  OK
Beam Design 2025A5
1/9/2025 5
ΔLL = = 0.12 in.
(L/d)LL = 84.00 / 0.12 = 691
 ΔLL = 0.12 in = L/691 < L/360   ➜  OK
ΔTL = = 0.13 in.
(L/d)TL = 84.00 / 0.13 = 630
 ΔTL = 0.13 in = L/630 < L/240   ➜  OK
fc⊥ = = 132.7 psi
 fc⊥ = 132.7 psi < Fc⊥x' = 425.00 psi  (CSI = 0.31)   ➜  OK
Beam Design 2025A5
1/9/2025 6
