Design Span (L): 5.54 ft.
Clear Span: 5.08 ft.
Total Span: 6.00 ft.
Bearing (lb): 5.5 in.
Live Load: 375 plf
Dead Load: 125 plf
Selfweight: 16.1 lbs
Dist. Selfweight: 2.91 plf
Total Weight: 17.5 lbs
Beam Design 2025A47
2/18/2025 1
Beam Design 2025A47
2/18/2025 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (66.50 + 5.5)] x (12 in./ft.)3 = 0.45 ft3
Volumespan = N[A x L] = 1 x [10.88 x 66.50] x (12 in./ft.)3 = 0.42 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 0.45 = 17.5 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 0.42 = 16.1 lbs
375 plf
125 plf
ws = 2.91 plf
5.54 ft.
5.08 ft.
1508.83 lbs
1508.83 lbs
Beam Design 2025A47
2/18/2025 3
Fbx' = (925)(1.00)(1)(1)(1)(1)(1)(1) = 925.0 psi
fb = = 1763.2 psi
 fb = 1763.2 psi > Fbx' = 925.0 psi  (CSI = 1.91)   ➜  NG
Beam Design 2025A47
2/18/2025 4
fv* = = 150.31 psi
 fv* = 150.31 psi < Fvx' = 169.75 psi  (CSI = 0.89)   ➜  OK
fv = = 192.22 psi
 fv = 192.22 psi > Fvx' = 169.75 psi  (CSI = 1.13)   ➜  NG
Beam Design 2025A47
2/18/2025 5
ΔLL = = 0.13 in.
(L/d)LL = 66.50 / 0.13 = 501
 ΔLL = 0.13 in = L/501 < L/360   ➜  OK
ΔTL = = 0.18 in.
(L/d)TL = 66.50 / 0.18 = 374
 ΔTL = 0.18 in = L/374 < L/240   ➜  OK
fc⊥ = = 182.9 psi
 fc⊥ = 182.9 psi < Fc⊥x' = 378.55 psi  (CSI = 0.48)   ➜  OK
Beam Design 2025A47
2/18/2025 6
