Design Span (L): 5.54 ft.
Clear Span: 5.08 ft.
Total Span: 6.00 ft.
Bearing (lb): 5.5 in.
Live Load: 375 plf
Dead Load: 125 plf
Selfweight: 32.3 lbs
Dist. Selfweight: 5.83 plf
Total Weight: 35.0 lbs
Beam Design 2025A45
2/18/2025 1
Beam Design 2025A45
2/18/2025 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (66.50 + 5.5)] x (12 in./ft.)3 = 0.91 ft3
Volumespan = N[A x L] = 2 x [10.88 x 66.50] x (12 in./ft.)3 = 0.84 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 0.91 = 35.0 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 0.84 = 32.3 lbs
Distributed Self Weight (ws) = = 5.83 plf
375 plf
125 plf
ws = 5.83 plf
5.54 ft.
5.08 ft.
1517.57 lbs
1517.57 lbs
Beam Design 2025A45
2/18/2025 3
Fbx' = (925)(1.00)(1)(1)(1)(1)(1)(1) = 925.0 psi
fb = = 886.7 psi
 fb = 886.7 psi < Fbx' = 925.0 psi  (CSI = 0.96)   ➜  OK
Beam Design 2025A45
2/18/2025 4
fv* = = 75.59 psi
 fv* = 75.59 psi < Fvx' = 169.75 psi  (CSI = 0.45)   ➜  OK
fv = = 96.67 psi
 fv = 96.67 psi < Fvx' = 169.75 psi  (CSI = 0.57)   ➜  OK
Beam Design 2025A45
2/18/2025 5
ΔLL = = 0.07 in.
(L/d)LL = 66.50 / 0.07 = 1003
 ΔLL = 0.07 in = L/1003 < L/360   ➜  OK
ΔTL = = 0.09 in.
(L/d)TL = 66.50 / 0.09 = 744
 ΔTL = 0.09 in = L/744 < L/240   ➜  OK
fc⊥ = = 92.0 psi
 fc⊥ = 92.0 psi < Fc⊥x' = 378.55 psi  (CSI = 0.24)   ➜  OK
Beam Design 2025A45
2/18/2025 6
