Size: 4 x 8
Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 210 plf
Dead Load: 105 plf
Selfweight: 46.7 lbs
Dist. Selfweight: 6.03 plf
Total Weight: 48.2 lbs
Beam Design 2025A38
2/10/2025 1
Beam Design 2025A38
2/10/2025 2
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (93.00 + 3)] x (12 in./ft.)3 = 1.41 ft3
Volumespan = N[A x L] = 1 x [25.38 x 93.00] x (12 in./ft.)3 = 1.37 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.41 = 48.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.37 = 46.7 lbs
210 plf
105 plf
ws = 6.03 plf
7.75 ft.
7.50 ft.
1284.11 lbs
1284.11 lbs
Beam Design 2025A38
2/10/2025 3
lu/d = = 3.31
Rb = = 5.41
 Rb = 5.41 < 50   ➜  OK
Beam Design 2025A38
2/10/2025 4
FbE = = 23786.41 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.15)(1)(1)(1.3)(1)(1) = 1345.50 psi
CL =   = 0.997
Fbx' = (900)(1.15)(1)(1)(0.997)(1.3)(1)(1) = 1341.5 psi
fb = = 943.3 psi
 fb = 943.3 psi < Fbx' = 1341.5 psi  (CSI = 0.70)   ➜  OK
fv* = = 62.07 psi
 fv* = 62.07 psi < Fvx' = 207.00 psi  (CSI = 0.30)   ➜  OK
fv = = 73.54 psi
 fv = 73.54 psi < Fvx' = 207.00 psi  (CSI = 0.36)   ➜  OK
Beam Design 2025A38
2/10/2025 5
ΔLL = = 0.10 in.
(L/d)LL = 93.00 / 0.10 = 970
 ΔLL = 0.10 in = L/970 < L/240   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 93.00 / 0.15 = 635
 ΔTL = 0.15 in = L/635 < L/180   ➜  OK
fc⊥ = = 122.3 psi
 fc⊥ = 122.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.20)   ➜  OK
Beam Design 2025A38
2/10/2025 6
