Size: 3.125 x 16.5
Design Span (L): 21.75 ft.
Clear Span: 21.50 ft.
Total Span: 22.00 ft.
Selfweight: 262.9 lbs
Dist. Selfweight: 12.09 plf
Total Weight: 266.0 lbs
Beam Design alfredo garcia 5315 W SHAW BUTTE DR 1
1/30/2025 1
b = 3.125 in.
d = 16.500 in.
A = 3.125 x 16.500 = 51.56 in.2
Sx = (3.125)(16.500)2/6 = 141.80 in.3
Sy = (3.125)2(16.500)/6 = 26.86 in.3
Ix = (3.125)(16.500)3/12 = 1169.82 in.4
Iy = (3.125)3(16.500)/12 = 41.96 in.4
1/30/2025 2
Volumetotal = N[A x (L + lb)] = 1 x [51.56 x (261.00 + 3)] x (12 in./ft.)3 = 7.88 ft3
Volumespan = N[A x L] = 1 x [51.56 x 261.00] x (12 in./ft.)3 = 7.79 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 7.88 = 266.0 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 7.79 = 262.9 lbs
Distributed Self Weight (ws) = = 12.09 plf
  ws = 12.09 plf
21.75 ft.
21.50 ft.
22.00 ft.
2057.98 lbs
2057.98 lbs
1/30/2025 3
fb = = 936.2 psi
 fb = 936.2 psi < Fbx' = 2760.0 psi  (CSI = 0.34)   ➜  OK
1/30/2025 4
fv* = = 51.70 psi
 fv* = 51.70 psi < Fvx' = 304.75 psi  (CSI = 0.17)   ➜  OK
fv = = 59.19 psi
 fv = 59.19 psi < Fvx' = 304.75 psi  (CSI = 0.19)   ➜  OK
1/30/2025 5
ΔLL = = 0.24 in.
(L/d)LL = 261.00 / 0.24 = 1091
 ΔLL = 0.24 in = L/1091 < L/180   ➜  OK
ΔTL = = 0.45 in.
(L/d)TL = 261.00 / 0.45 = 583
 ΔTL = 0.45 in = L/583 < L/120   ➜  OK
fc⊥ = = 219.5 psi
 fc⊥ = 219.5 psi < Fc⊥x' = 650.00 psi  (CSI = 0.34)   ➜  OK
1/30/2025 6
