Grade: 24F-V3 1.8E SP/SP
Size: 5.5 x 22
Design Span (L): 31.66 ft.
Clear Span: 30.66 ft.
Total Span: 32.66 ft.
Bearing (lb): 12 in.
Live Load: 335 plf
Selfweight: 981.4 lbs
Dist. Selfweight: 31.00 plf
Total Weight: 1012.4 lbs
CV Volume Factor 0.947b - - - - -
Beam Design 2025A3
1/6/2025 1
d = 22.000 in.
A = 5.500 x 22.000 = 121.00 in.2
Sx = (5.500)(22.000)2/6 = 443.67 in.3
Sy = (5.500)2(22.000)/6 = 110.92 in.3
Ix = (5.500)(22.000)3/12 = 4880.33 in.4
Iy = (5.500)3(22.000)/12 = 305.02 in.4
Beam Design 2025A3
1/6/2025 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [121.00 x (379.92 + 12)] x (12 in./ft.)3 = 27.44 ft3
Volumespan = N[A x L] = 1 x [121.00 x 379.92] x (12 in./ft.)3 = 26.60 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 27.44 = 1012.4 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 26.60 = 981.4 lbs
Distributed Self Weight (ws) = = 31.00 plf
335 plf
  ws = 31.00 plf
31.66 ft.
30.66 ft.
32.66 ft.
7201.49 lbs
7201.49 lbs
Beam Design 2025A3
1/6/2025 3
CV = = 0.947
CV = 0.947 < CL = 1
Fbx' = (2400)(1.00)(1)(1)(0.947) = 2273.0 psi
fb = = 1494.5 psi
 fb = 1494.5 psi < Fbx' = 2273.0 psi  (CSI = 0.66)   ➜  OK
Beam Design 2025A3
1/6/2025 4
fv* = = 76.52 psi
 fv* = 76.52 psi < Fvx' = 300.00 psi  (CSI = 0.26)   ➜  OK
fv = = 86.54 psi
 fv = 86.54 psi < Fvx' = 300.00 psi  (CSI = 0.29)   ➜  OK
Beam Design 2025A3
1/6/2025 5
ΔLL = = 0.86 in.
(L/d)LL = 379.92 / 0.86 = 441
 ΔLL = 0.86 in = L/441 < L/360   ➜  OK
ΔTL = = 1.13 in.
(L/d)TL = 379.92 / 1.13 = 335
 ΔTL = 1.13 in = L/335 < L/240   ➜  OK
Ab = b x lb = 5.5 x 12 = 66.00 in2
fc⊥ = = 109.1 psi
 fc⊥ = 109.1 psi < Fc⊥x' = 740.00 psi  (CSI = 0.15)   ➜  OK
Beam Design 2025A3
1/6/2025 6
