Grade: SPF SS
Size: 4 x 6
Live Load: 100 lbs
Dead Load: 75 lbs
Selfweight: 91.4 lbs
Dist. Selfweight: 7.78 plf
Total Weight: 93.4 lbs
Orientation: Horizontal
Beam Design 2025A29
1/27/2025 1
Beam Design 2025A29
1/27/2025 2
Volumetotal = N[A x (L + lb)] = 2 x [19.25 x (141.00 + 3)] x (12 in./ft.)3 = 3.21 ft3
Volumespan = N[A x L] = 2 x [19.25 x 141.00] x (12 in./ft.)3 = 3.14 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 3.21 = 93.4 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 3.14 = 91.4 lbs
Distributed Self Weight (ws) = = 7.78 plf
100 lbs
75 lbs
ws = 7.78 plf
134.18 lbs
134.18 lbs
Beam Design 2025A29
1/27/2025 3
Fby' = (1250)(1.15)(1)(1)(1)(1.3)(1.05)(1)(1) = 1962.2 psi
fb = = 346.4 psi
 fb = 346.4 psi < Fby' = 1962.2 psi  (CSI = 0.18)   ➜  OK
Beam Design 2025A29
1/27/2025 4
Fvy' = (135)(1.15)(1)(1)(1) = 155.25 psi
fv* = = 5.10 psi
 fv* = 5.10 psi < Fvy' = 155.25 psi  (CSI = 0.03)   ➜  OK
fv = = 5.19 psi
 fv = 5.19 psi < Fvy' = 155.25 psi  (CSI = 0.03)   ➜  OK
Ey' = Ey(CM)(Ct)(Ci) = 1500000(1)(1)(1) = 1500000 psi
Beam Design 2025A29
1/27/2025 5
ΔLL =   =   = 0.10 in.
(L/d)LL = 141.00 / 0.10 = 1423
 ΔLL = 0.10 in = L/1423 < L/360   ➜  OK
ΔTL =   =   = 0.23 in.
(L/d)TL = 141.00 / 0.23 = 613
 ΔTL = 0.23 in = L/613 < L/240   ➜  OK
Fc⊥y' = (425)(1)(1)(1) = 425.00 psi
Ab = d x lb = 5.5 x 3 = 16.50 in2
fc⊥ = = 4.1 psi
 fc⊥ = 4.1 psi < Fc⊥y' = 425.00 psi  (CSI = 0.01)   ➜  OK
Beam Design 2025A29
1/27/2025 6
